XC Oil & Filter - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 10-16-2011, 09:14 PM Thread Starter
Default XC Oil & Filter
I would like to change to synthetic oil after break-in on my 2012 XC. Also, I think Walmart has an excellent oil filter for motorcycles, much cheaper than Vic filter. Anyone try synthetic oil an an non-OEM filter?
I uses synthetic oil and non OEM filters on my previous bikes (HD's, and Honda's)
Thanks a bunch!!
Lphelps5 is offline
post #2 of 18 (permalink) Old 10-16-2011, 09:47 PM
LazyDawg's Avatar
I am very curious about this subject also. I have searched this forum with not many results. Good post, I need to keep watching this one
Him: 2011 XC Pearl White/Silver
Her: 2013 XC Sunset Red
LazyDawg is offline
post #3 of 18 (permalink) Old 10-16-2011, 09:59 PM
There's a lot of info out there on this subject. Don't know why it's not coming up for your searches but it's there. Wix makes a really good oil filter. Not sure if Walmart has it but I know O' Reilly's does and Advanced Auto if you have those stores. O Reilly's by me keeps them in the back so you have to ask for them vs just pick off the shelf. I switched mine to Full Sythnetic right after the break in oil was dropped. I was using Mobil 1 10W40 Motorcycle Racing oil since that most closely matched Vic's viscosity requirements vs 20W50. Thicker isn't necessarily better so don't buy into that hype. I have recently switch to Mobil 1 5W40 Turbo Diesel Oil and the K & P cleanable oil filter and I'm happy with that combo so far. I can get the oil at Walmart or O Reilly's and I don't need to buy the oil filter anymore. AMSOIL beekens, flame away!!!!
40XC is offline
post #4 of 18 (permalink) Old 10-16-2011, 10:36 PM
CrossRoads's Avatar
Default Oil & Lube
Who has noticed the Oil and Lube section of this forum, please raise your hand. Nobody? Oh, okay... Here it is: https://www.victoryforums.com/forumdisplay.php?f=25
Btw, moving this thread to the Oil & Lube section, where it will be in good company.
CrossRoads is offline
post #5 of 18 (permalink) Old 10-17-2011, 02:02 AM
I see they now have 10w/40w Valvoline dino oil for bikes and the 10w/40w Synth oil for bikes available at Autozone and Walmart. I figure I'll put in 2 quarts synth and the rest dino with the Valvoline. I think I'll use the Supertech filter again. Seems to work fine so far. Might look for a wix though...
Here's a list plagiarized from another forum.
Some numbers for you. This list comes from other sites, but all that I have tried have fit...
These Oil Filters have 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket 2.5" to 3.5" long. If you have the room, the longer filters are recommended.
Motorcycle Filters.
•AC Delco PF2135
•AMSOil SMF103
•Carquest 85358
•AC Delco PF2135
•FRAM PH6017A
•Honda 15410-MCJ-000
•K&N KN-204. Metric nut on end for easy removal.
•NAPA Gold 1358
•Purolator ML16817. Imported, not made by Purolator.
•STP SMO 17
•WIX 51358
Recommended filters.
All have superior filtering.
About 2.5 inches long.
•Purolator Pure One PL14612.
•Mobil M1-108. Made by Champion.
•Bosch 3300. Made by Champion.
•Wal-Mart SuperTech ST6607. Made by Champion.
About 3.25 inches long.
•Purolator Pure One PL14610.
•Mobil 1 M1-110. Made by Champion.
•Bosch 3323. Made By Champion.
•WalMart SuperTech ST7317. Made by Champion.
Automobile Filters, about 2.5 inches long.
•AC Delco PF1237
•Baldwin B1400
•Firestone TF2876
•Hastings LF113
•NAPA Gold 1365
•Purolator L14612
•STP S-02876
•WalMart SuperTech ST6607
•WIX 51365
Automobile Filters, about 3.25 inches long.
•AC Delco PF-2057
•Auto Pro 2356
•Autopride CF240AP
•Baldwin B1402
•Carquest 85356
•Carquest Red B4620
•Casite CF240
•Castrol 7317
•Champion Labs Ph2867
•Defense Filters Dl7317
•Deutsch D-370
•Federated Filters LF240F
•Fram Double Guard DG7317
•Fram PH7317
•Fram Tough Guard TG7317
•Fram Xtra Guard XG7317
•Group 7 V4610
•Group 7 V4620
•Hastings LF240
•Mighty M4612
•Motorcraft Long Life FL-821
•Napa FIL1356
•Napa Gold 1356
•Parts Plus PH2867
•Pennzoil PZ-109
•Penske 7317
•Powerflo SL14610
•Powerflo SL14620
•Pro Gauge PGO-4620
•Pro Tec 164
•Promotive PH4610
•Pronto PO3593A
•Purolator L14610
•Service Champ OF-4622
•Shell SH48
•Shell SH529
•STP S-02867.
•Valvoline VO50
•Warner PH2867
•Wix 51356
BBob is online now
post #6 of 18 (permalink) Old 01-20-2012, 08:00 AM
gibson's Avatar
the WIX number you have is WRONG it is suppose to be 51356
gibson is offline
post #7 of 18 (permalink) Old 01-20-2012, 12:16 PM
51356 is the short one
51358 is the long one most use the long one cause we don't have clearance issues
post #8 of 18 (permalink) Old 01-20-2012, 01:22 PM
gibson's Avatar
Just going by my book number does not show the short one. sorry bud
gibson is offline
post #9 of 18 (permalink) Old 01-20-2012, 04:00 PM
Motorcycle Filters.
•AC Delco PF2135
•AMSOil SMF103
•Carquest 85358
•AC Delco PF2135
•FRAM PH6017A
•NAPA Gold 1356
•STP SMO 17
•WIX 51356
•AC Delco PF1237
•Baldwin B1400
•Firestone TF2876
•Hastings LF113
•NAPA Gold 1356
•Purolator L14612
•STP S-02876
•WIX 51356
•AC Delco PF-2057
•Auto Pro 2356
•Autopride CF240AP
•Baldwin B1402
•Carquest 85356
•Carquest Red B4620
•Casite CF240
•Castrol 7317
•Deutsch D-370
•Fram PH7317
•Group 7 V4610
•Group 7 V4620
•Hastings LF240
•Mighty M4612
•Napa FIL1356
•Napa Gold 1356
•Parts Plus PH2867
•Pennzoil PZ-109
•Penske 7317
•Powerflo SL14610
•Powerflo SL14620
•Pro Gauge PGO-4620
•Pro Tec 164
•Promotive PH4610
•Pronto PO3593A
•Purolator L14610
•Shell SH48
•Shell SH529
•STP S-02867.
•Valvoline VO50
•Warner PH2867
•Wix 51356
It won't let me change it so I just quoted it to change it. Thanks for catching the mistake.
Last edited by BBob; 01-20-2012 at 04:05 PM. Reason: Napa Gold was wrong too. Fixed now.
BBob is online now
post #10 of 18 (permalink) Old 02-08-2012, 06:16 PM
I changed my oil in my 08 Vegas to Amsoil 10w40 and Supertech ST7317 oil filter. So far all is well. I know you're looking for XR experience, but the motors are almost the same. I'll post again if I have any trouble.
2011 Crimson Cross Roads
vegas08 is offline
