Wix & Victory - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 06-03-2014, 04:55 PM Thread Starter
Triride44's Avatar
Default Wix & Victory
Been using Wix 51356 filter, and wanted to compare it to the Victory filter. After cutting open two new filters I can say with confidence that the Victory filter is made by Wix. However there are some differances.
The wix filter has the by-pass valve between the base plate and the filter element. The Wix has the by-pass valve in the metal end cap above the filter element. The Victory filter pleats are evenly spaced and gather togather with a metal clip. Other wise they look alike.
Triride44 is offline
post #2 of 15 (permalink) Old 06-03-2014, 04:58 PM
Subscribed
2013 Victory Hammer 8-Ball
mobgma is offline
post #3 of 15 (permalink) Old 06-03-2014, 05:36 PM
GatorJoe's Avatar
Had Good Results with Wix Filters and not just on my XC ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #4 of 15 (permalink) Old 06-03-2014, 05:44 PM
vindex1963's Avatar
Thanks for taking the time to chop up a couple filters. Interesting info I wonder how a Mobil 1 M-110 would compare.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #5 of 15 (permalink) Old 06-03-2014, 07:11 PM
RedRocker's Avatar
Post
Yes, Thanks for your efforts to share the info/photos on the filters.
Well done!
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #6 of 15 (permalink) Old 06-03-2014, 07:43 PM
Lostintexas's Avatar
Champion Labs make Mobile 1 filters and they are a solid offering. Bosch comes from Champion as well. I have suspected WIX of making the Vic filters as well, along with several others.
In actuality there aren't a lot of filter makers. They produce them to "spec" for a brand and go from there.
Here is some reading for you. It is older and some things have changed over time, but you'll get the jist. http://motorcycleinfo.calsci.com/FilterStudy.html
The author prefers Puolator pure one filters, but in all if you read around and look at what is shown, you'll see there are plenty of good ones out there and the prices really don't have a lot to do with the quality.
Cheers
I ride with the Force.
Lostintexas is offline
post #7 of 15 (permalink) Old 06-03-2014, 08:40 PM
wesdalton's Avatar
Great info, but why not just buy the Vic filter?
2010 X C
wesdalton is offline
post #8 of 15 (permalink) Old 06-03-2014, 08:43 PM
blueracer17's Avatar
My guess is because you can pick up the Wix for less than the Vic, and the Wix can be bought at almost any parts store.
2004 Kingpin
Mustang Seat, Progressive 465 shock, RPW Thor Exhaust, VFC III, S&S Intake, Ness Fly bars, Kuryakyn ISO Grips and throttle boss, Kuryakyn Silver Bullets, Ness laydown plate bracket, Barnett braided clutch cable....
blueracer17 is offline
post #9 of 15 (permalink) Old 06-03-2014, 09:29 PM
Just asking are there the same number of plets in the paper?
Wix filter auto zone $6.99
post #10 of 15 (permalink) Old 06-03-2014, 10:15 PM
wesdalton's Avatar
That is true, and there more honda dealers around than vic's, and they are also cheaper than vic's. So what is the point??
2010 X C
