Oil reports - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 11-27-2011, 09:38 AM Thread Starter
vindex1963's Avatar
Default Oil reports
I love oil threads and the scientific ways they are approached. Victory recommends it (yea pretty good), sounds good (not so good) and looks good (really not so good).
So people use a specified oil because it looks and sounds good. Gotta love it.
I was wondering if anybody had a used oil analysis to back up the looks good and sounds good reviews? I have some but their not Victory but they are from a couple bikes that are ridden daily in 115 degree weather.
I have never owned an all in one oil bike before so this is new to me and I would like solid facts instead of looks/sounds good. Maybe the Amsoil guys here could post up some U.O.A.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #2 of 19 (permalink) Old 11-27-2011, 09:54 AM
PlowTown Missile's Avatar
This thread seems like it was just started to cause arguments. There are quite a few people with 100k miles on their Victories. Why not just ask what oil does everyone use and how many miles are in their bikes?
2007 Hammer, 260 Metz, Shotgun exhaust, S3 cams, LED hidden turn signals, HID Hi/lo headlights, a few Ness accessories, S&S intake, PC3, and dyno tune.
Build/tuning by WFO Motorsports
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
PlowTown Missile is offline
post #3 of 19 (permalink) Old 11-27-2011, 10:08 AM Thread Starter
vindex1963's Avatar
Nope not at all I was hoping to see some U.O.A. reports. I live where the temps can be 110+ for days and weeks at a time. I know any good quality oil works but some facts to back them up are good also.
Starting arguments isn't my style and is fruitless for gaining information. Information sir was my intention, that's all.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #4 of 19 (permalink) Old 11-27-2011, 10:16 AM Thread Starter
vindex1963's Avatar
Asking people what kind of oil they use is a tired subject and just brings out the sarcasm.
Here is a sample of what I'm talking about. Again not Victory but good information.
My 09 Ultra. This oil was tortured by running at extreme heat for extended periods of time riding 2-up across Arizona into California weekend after weekend. 270deg+ sometimes exceeding 300deg oil temp.
The TBN is very good!! and at 5000 miles.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 19 (permalink) Old 11-27-2011, 10:23 AM
It's all good but the oil discussions usually just come down who used what, how they like it, and how much money they saved.
The Vic tech that built my bike is now a service manager at his dealership (a very reputable dealership at that) and we had friends in common long before I owned a Victory. He's built lots of Vics for people (130+HP). When we talked on the phone right after I bought my bike, he told me immediately to always use Victory oil due to the horror stories of people who brought bikes in for repairs when they tried to run different oils. That was good enough for me.... oil gets changed every 2,500 miles regardless with Vic oil.
Edit: I've read lots of oil reports from people on engine building forums. Seen ones claiming Amsoil, Royal Purple, etc are doing amazing in their engines to find out later that their engine scattered on them prematurely. Excluding engines in a toy of mine where the manufacturer recommends a synthetic or semi-synthetic, I run regular dino oil.
Reason being is that I had a top rated national engine builder put together a new race motor for one of my cars and it was run with a custom full synthetic blend recommended for the engine by both the oil manufacturer and engine builder. When the engine spun TWO rod bearings simultaneously, it was 3k rpm UNDER redline and the engine was only 3 months old, less than 20 passes, and under 1,500 miles. Dino oil and I hand assemble all my own engine builds after I check the tolerances myself to verify everything is what it was spec'd at.
The problem with oil reports is that even it comes back your engine is wearing prematurely, it could be due to one of your clearances being on the tight side of the factory tolerances. Factory built motors have bigger tolerances for machine work than custom builds so you can't even compare two oil reports from two separate factory built motors.
post #6 of 19 (permalink) Old 11-27-2011, 10:44 AM
ridinman's Avatar
I've put over 125K on a Goldwing using Honda oil, 68K on a Ultra Classic using HD oil, and in 5 months, I've put 16K on my XC using Victory oil. I've had several other bikes and always used what the manufacturer recommended.
The only oil related problem I've ever had was the oil pump on my HD. They never told me what caused the oil pump to fail, they just replaced it. I rode that bike another 2 years.
Manufacturers don't blend the oil or make the filters. I was surprised to find how many motors the XC filter fits. Here's the cross reference list from Wix filters. http://www.wixfilters.com/filterlook...asp?Part=51356 I'm not recommending their filters, just used their list.
Somewhere I've seen posted who actually blends the oil for Victory, but I cant find the post. I don't know who makes the filters.
Now I'll sit back and watch where this thread goes.
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #7 of 19 (permalink) Old 11-27-2011, 11:43 AM Thread Starter
vindex1963's Avatar
I hope it doesn't go the way most go. I use XXX and had no problems. That doesn't mean a thing. My sample from above was coal black and tested good. Looks also mean nothing.
I am looking at extended changes if possible or reasonable. I've read of 100,000 mile plus Victory's changing at 5000 miles. Maybe Victory oil/filters doesn't have what it takes to go 5000 miles.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #8 of 19 (permalink) Old 11-27-2011, 12:50 PM
ridinman's Avatar
For the 2011 models, at least for the XC, Victory changed the recommended oil change interval to 5000 miles. The 2010 XC they recommend every 2500 miles. Same oil, same filter. I believe they made the change across all models but no updated recommendations for prior models.
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #9 of 19 (permalink) Old 11-27-2011, 01:14 PM
Polaris gets there oil from Lube Tech and I'm sure Polaris tells them what they want from the oil.
For PlowTown Missile spinning rod bearing the way you tell us its the guy that built the motor that doesn't know his oil or bearings. The oil really was not the bad guy but the motor builder was.
For years hd never used synthetic oil cause they did not have the right rod bearings to handle synthetic.
In 2008 or earlier most if not all started using the correct components so consumers could run synthetic oils.
I'll bet if you ran your Polaris oil to 5000 miles and then had it analyzed you would find your doing ok. In hot weather when it gets to 100 degrees or better yes changing you oil sooner does help.
Keep in mind that 90% of engine wear comes at start up and if your a rider that rev's your engine when its cold your 99% hurting your motor.
post #10 of 19 (permalink) Old 11-27-2011, 04:03 PM
wesdalton's Avatar
All Oil posts SUCK!
2010 X C
wesdalton is offline
