My Victory needs a tune up. Please Help! - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 06-13-2009, 11:27 AM Thread Starter
New Member
Default My Victory needs a tune up. Please Help!
I have a 1999 victory v92c thats giving me some problems. while riding at a steady speed it has a miss that causes it to jerk, spit, pop, and some times backfire. Sometimes when coming to a stopsign I'll have trouble keeping it running. But when I gun the throttle it seems to come out of it and seems to accelerate just fine. I've put new sparkplugs in it. I removed the entire fuel intake system and cleaned it. I removed the the injectors and cleaned them with carburator cleaner. I've checked for any unplugged wires, Ive run several fresh tanks of gas through it with sea foam fuel cleaner and I just cant seem to fix this problem and Im ready to give up on it! If anybody has experinced any problems similar to these please help. Oh, and also once in a while my oil light comes on, bright sometimes and sometimes dim. Thanks.
ctjcatman is offline
post #2 of 3 (permalink) Old 06-15-2009, 08:32 PM
Cool
'm having a similiar problem,the shop is telling it could be a stator or a rectifier it;s going in the shop on thurs.80bucks for a look see and hopefully a bike to ride good luck with your problem
nefv92 is offline
post #3 of 3 (permalink) Old 07-24-2009, 09:17 PM
Have you checked the intake adapter under the throttle body. They have a tendency to delaminate and cause air leaks. The V92C isnt really known very well for being the best in the Victory line-up, seeing how it's the very first Victory bike built, it has a lot of kinks and issues. Does the bike have aftermarket exhaust? Have the throttle bodies been recalibrated recently?( Should be done by a dealer, or someone with access to Digital Wrench, and the correct adapters). Not sure if any of this helped, Hope so.
LAALLARD is offline
