Oil Change Intrervals - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 01-19-2012, 10:57 AM Thread Starter
BeoBob's Avatar
Default Oil Change Intrervals
2011 Victory Cross Country. I have about 3,500 miles on this oil change. Here in the last week the engine has started getting a little noisey. With some of my past machines the increased noise was an indicator to me that it was time for an oil change. Some machines would stay quite regardless of the miles, where others will only get to 3K before telling me it’s time for an oil change.
So yesterday I went to the local dealer to buy a Victory oil change kit. The last one cost me $60… OK. But this one cost me $80!!!! Not all that bad considering what you get. But dang, a $20 jump?
Which leads to my questions… For those of you who have the 2011 and up 106ci engine and are using Victory oil:
- Do you notice more noise as the oil gets old(er)?
- If so, how many miles before you start to hear it?
- How often are you changing the oil?
Thanks in advance.
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #2 of 15 (permalink) Old 01-19-2012, 11:34 AM
CrossRoads's Avatar
For what it's worth, I do oil changes at 5,000 miles as recommended and each and every time oil comes out looking like it's only half way through its life. Of course, this is just my visual test. Noise wise, I did not notice changes in noise as the oil ages.
CrossRoads is offline
post #3 of 15 (permalink) Old 01-19-2012, 12:33 PM
So many times we hear things that are not there. One bike I had I swear I heard a noise from the rear wheel but never could find any thing wrong. By chance I was away from the bike for two weeks. When I did get back on the bike no more noise.
Kinda like you'll read guys say the bike shifts hard when it get close to oil change time. I think thats all in your mind.
If you didn't see the mileage would you have the same thoughts.
I went to Amsoil oil and a Wix filter and pay about $55 bucks for a change. I do think your dealer bent you over and I would save your reset and keep an eye on there prices and when it goes down I would ask them why.
post #4 of 15 (permalink) Old 03-10-2012, 12:20 PM
Default Oil change/ noises
I bought my 09 Victory Vision Tour in February '10 new as a leftover. Primarily because it came with a 5 year factory warranty. Because the day was cold when I took the test ride the bike (transmission) was quiet. Since then I noticed as the ambient temperature allowed the machine to get to 225 or so degrees, I hear objectional gear noise. I think if I had test rode the Victory in the summer, I would not have bought it. I have heard the '12 model has corrected that issue.
Frank
FLEONE1 is offline
post #5 of 15 (permalink) Old 03-10-2012, 02:58 PM
Can you define Objectionable? What's the dealer say? Try Kicker speakers and turn the radio up?
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #6 of 15 (permalink) Old 03-10-2012, 07:13 PM
saddlebag's Avatar
No.
Every 5k miles per the manual.
2011 Cross Roads
saddlebag is offline
post #7 of 15 (permalink) Old 03-10-2012, 07:16 PM
saddlebag's Avatar
I did the airbox insulative strip removal mod and when I first started the engine after it sat for a month or so over winter, a very loud ticking sound came from the airbox. The engine oil was just changed before I put it away. After it had run for a few minutes, it went away.
2011 Cross Roads
post #8 of 15 (permalink) Old 03-10-2012, 08:54 PM
New Member
I bought a Vic oil change kit like two weeks ago and it was $60.
TrashmanNYC is offline
post #9 of 15 (permalink) Old 03-11-2012, 11:57 AM
Oil more then likely drained out of your cam chain adjuster is what the ticking you heard. Good for you it went away.
post #10 of 15 (permalink) Old 04-11-2012, 03:21 PM
buddoggin's Avatar
Does the 5000 mile interval apply to all freedom motors?? as in my 2003 92" Vegas?
buddoggin is offline
