Victory Oil Change Kits - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 08-17-2014, 12:59 AM Thread Starter
Default Victory Oil Change Kits
Was wondering if these kits fit the 2015 Gunner. On the victory website it says it does not but I thought it would since it is the same 106 engine?
norcalgunner is offline
post #2 of 13 (permalink) Old 08-17-2014, 02:09 AM
Rebel Biker's Avatar
Yes it will. That's typical with a new bike. If you bought a new '14 CCT a while back for example, and went online looking for accessories, a lot of them said it wouldn't fit but if you changed the year to the '13 it would say it fits. Same bike! They just didn't update their site for all the goodies. That's what you're experiencing. You can't go back to the previous year but none the less, you're good on the oil
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #3 of 13 (permalink) Old 09-26-2014, 03:31 PM
20isPlenty's Avatar
I'm piggy-backing on this thread so I don't have to ask a question that has already been answered.
I just did my first oil change on my Vision (2010). It was easy, but the kit (Victory oil change kit) had 3 gaskets in it (one rubber, 2 copper). I followed the instructions very carefully, making sure to note where any gaskets came off. There is only one on the Vision. It is the drain plug, which I replaced. The oil filter had one already on it, so I smeared a little oil on that one and replaced it, as I've done my whole life. There were 2 gaskets left. They look to be about the size of the filter screw (whatever that thing is called), but my bike did not have anything but the filter gasket, and it hasn't used a drop of oil since I bought it. I would like to confirm my suspicion that the other 2 gaskets are used on the 100 CI engine. Can someone tell me for sure? If I missed anything, I need to know, because I plan on a road trip tomorrow.
Here's a picture (the dime is for reference):
Stu D
USN (ret)
2010 Vision
20isPlenty is offline
post #4 of 13 (permalink) Old 10-12-2014, 10:58 AM
Pckrfan's Avatar
both 106 engines I had/have only took the one copper gasket for the drain plug. the others, it was explained to me, were for the earlier engines. Kinda a one kit for all Vic engines.
2013 AG-XC:
Gustafsson +2 Euro Flip
JWSpeaker 8695 LED Headlight
Ma Vic (Black Tri-Ovals/S1 Package, pull backs, derby covers,
heated seat, bag bars, shorty antennae)
Ness Rad III mirrors, Avon heated grips, Wolo Bad Boy air horn
RICZ's LD PL8 bracket and lotsa blacked out stuff
GOODY'S fork mounted lowers (3M'd)
Bag graphics & inner fairing, Bad Boys Design Peoria, AZ.
Artificial intelligence is absolutely 100% NO MATCH...............for natural stupidity!
Pckrfan is offline
post #5 of 13 (permalink) Old 10-12-2014, 01:26 PM
Oldman47's Avatar
Check out your oil dipstick. I bet you will find a match for that rubber o ring.
Oldman47 is offline
post #6 of 13 (permalink) Old 10-29-2014, 01:34 PM
20isPlenty's Avatar
I'll double check on the next oil change, but I think I did look at it.
Stu D
USN (ret)
2010 Vision
post #7 of 13 (permalink) Old 10-29-2014, 01:39 PM
Default Easy!!!
easiest oil change ever! after break-in its highly advised to go to Amsoil from our sponsor + a wix-victory filter
rodhotter is offline
post #8 of 13 (permalink) Old 10-29-2014, 03:14 PM
20isPlenty's Avatar
For how many miles is that filter rated? Amsoil is supposed to be good for, what, 10k? 20k? If the filter is only rated for 5-7k, then why switch to Amsoil?
Stu D
USN (ret)
2010 Vision
post #9 of 13 (permalink) Old 10-29-2014, 04:03 PM
vindex1963's Avatar
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #10 of 13 (permalink) Old 10-29-2014, 08:27 PM
Default just change the filter!
on my car + pickup i run Amsoil for a year, rated for 25,000 with their filter, change filter @ 6 months using a wix. not many miles on them being retired. $7 for a wix or napa gold for the Hammer available most anywhere. having 2 bikes a bonneville + the hammer riding is unevenly split in the Hammer's favor. riding in PA is all but done for me + i have done my yearly oil + filter changes
