Cruise Control is intermittent - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 05-07-2012, 10:36 PM Thread Starter
Default Cruise Control is intermittent
I am right around 14500 miles on my 2011 CC. I have noticed for the last 3000 miles that my Cruise Control module will turn on but it will not always set. Has anyone else see this happening on there bikes? I talked to a 2008 Vision owner while I was getting my rear tire changed and before I had this start happening and he told me he had his Cruise Control start messing up and it ended being the Master Cylinder going out.
2011 CROSS COUNTRY
pdsmith is offline
post #2 of 8 (permalink) Old 05-07-2012, 10:39 PM
CrossRoads's Avatar
Check your clutch switch, front brake switch and rear brake switch. One of them is likely not working properly anymore. There's a simple procedure in the service manual on how to test each switch. Good luck.
CrossRoads is offline
post #3 of 8 (permalink) Old 05-08-2012, 08:54 AM
ALStensby's Avatar
This unlikely the issue, but I'll throw it out there anyhow. Rain or washing the bike will typically cause issues like this as well so if it's been wet recently whenever it wasn't working, that could be the cause as well.
Adam
2011 Victory Cross Roads - His
2014 Indian Chief 'Springfield' - Hers
2013 Honda CB500F
ALStensby is offline
post #4 of 8 (permalink) Old 05-08-2012, 09:06 AM
smoke's Avatar
Mined turned out to be the throttle cable adjustments. A buddy of mine has had 3 Vic's and said he could get it.
He got it on the First shot. No problem since, about 4000 miles and 8 months ago, including winter here in PA.
Smoke XC
2013 AntiFreeze Green
D&D exhaust, Gust. Smoke +2 Flip or 7" Dk Smoke shield, Kickers with Rockford Fosgate Amp, Vic Pass. Backrest & lots of extra chrome.
2011 Victory Blue XC - Traded
2007 Honda Blue VTX - Traded
smoke is offline
post #5 of 8 (permalink) Old 05-08-2012, 03:20 PM
Same with mine, throttle cable adjustment. I'd suggest that first, then go onto the switches. It can be a "bear" when it is an intermittent problem.
2015 XCT Two Tone White/Gray
Ultimate Seat & Backrest
Custom Dynamics Non-Sequential License Plate Frame
Hyper-Lites
Kuryakyn #4178 Windshield Bag
Victory Bag Guards
Custom Dynamic Cool Magic Bullet LED Running Lights
+2" Back Bars
Victory Highway Pegs #2874837 & Z-Bracket
Kuryakyn Sabertooth LED's
Traded for a 2015 Cross Country Tour on 8-31-15
Previous bike was a 2010 Victory Cross Country-Midnight Cherry, had 54,xxx+ trouble free miles. Just needed a change & got a great deal.
rdeerx is offline
post #6 of 8 (permalink) Old 05-08-2012, 05:45 PM
depot picker's Avatar
You know it takes it 3 to 5 seconds to come ready before it will set when you turn it on?
depot picker is offline
post #7 of 8 (permalink) Old 05-08-2012, 06:24 PM Thread Starter
I will try the throttle cable 1st. If that doesn't work it is still in Warranty so I will take it to the dealer to check it out. I am aware of how long it takes for the cruise control to work. I have used it plenty of times before the issue started. No issues with cruise control the 1st 11500 miles.
2011 CROSS COUNTRY
pdsmith is offline
post #8 of 8 (permalink) Old 05-09-2012, 08:38 AM
Also check at the throttle body plate where the cable is secured (right side, just above and behind the cheese wedge) with two screws on either side. If one or both come loose, it can play havoc with your throttle and cruise.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
