Heat on left leg - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 05-18-2012, 10:06 PM Thread Starter
Default Heat on left leg
Hi all,
I have a 2012 XC. I am feeling a lot of heat on my left leg coming from the engine. I am not sure what is going on because I feel a lot of air coming toward my leg so I would suspect it would wash the engine and take the heat away from my leg.
THoughts?
Best
John
John Indianapolis IN
2012 cross country, Adam bomb mufflers
2007Kingpin (sold)
johnah5 is offline
post #2 of 5 (permalink) Old 05-18-2012, 11:51 PM
If there is a strong breeze coming from your right, that will cause you left leg to be warmer. Other than that, can't tell ya. I don't have that problem on my XR and I even keep my lower deflectors on all year around.
post #3 of 5 (permalink) Old 05-19-2012, 05:56 AM
RonBou's Avatar
Try only opening your lower vent just about two inches. Open more than that the wind pushes the engine heat to the back of your legs. Good pair of boots helps also to deflect some of the heat off your lower leg.
forget this post. I thought you had an XCT. Sorry!
Ron
2012 Victory Cross Country Tour (Stage 1)
2011 Victory Cross Country (traded in on XCT)
2009 Triumph Rocket III Touring (traded in on XC)
1998 Valkyrie Tourer (Hydralocked - sold as is)
1966 Honda 305 Dream (for sale)
1967 Honda 305 Scrambler (project)
1982 Honda CB900 Custom (need to put back together)
RonBou is offline
post #4 of 5 (permalink) Old 05-19-2012, 10:16 AM
DakotaRider's Avatar
I rode out to the Badlands earlier this week and the temps were in the high 80s/low 90s. Felt some heat on both legs, however it depended on the wind direction in relationship to my travel direction, but the heat did not seem excessive at that time. I didn't have the vents open nor move the clear one from it's normal position. All in all, a pretty nice ride too. Of course mine is an XCT, so XC is more than likely to feel different when the weather is warm (hot). Hope you find something that fits your comfort requirements.
Originally Posted by johnah5 View Post
Hi all,
THoughts?
Best
John
Winston - USAF Retired
Current Bike:
2012 Victory - Pearl White XCT - Dutchess
Rapid City, SD
Previous Bikes:
02 Goldwing - Stream Silver Metallic GL-1800
07 Goldwing - Dark Orange Metallic GL-1800
DakotaRider is offline
post #5 of 5 (permalink) Old 05-19-2012, 10:26 AM
Try disconnecting the O2 sensors. The connections are about 6" back from the sensors. This will richen the fuel mixture and let your motor run cooler. A fuel controller like the PCV w/AT would be a good addition to any closed loop Vic.
