humming noise - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 01-12-2015, 02:29 PM Thread Starter
45caldan's Avatar
Default humming noise
OK, I've read a bunch of threads about chirping belts.
Mine seems to be adjusted right per the manual but I get a lot of humming or moaning sounds coming from the rear.
Is this the belt or pulley or are my bearings going??
TIA,
Dan
2010 Cross Roads
Vic HP air filter
Stage 1
D&D slash cut mufflers
Lloyd's Adjustable Timing Wheel @ 4
Kuryakyn Engine Guard Driving lights
Sabertooth auxiliary tail lights
7jurock custom WS with vent
Cee Bailey lowers
Ness Tear Drop mirrors
45caldan is offline
post #2 of 15 (permalink) Old 01-12-2015, 02:35 PM
dtmmil's Avatar
have you lowered the rear at all? if so did you adjust after?
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 15 (permalink) Old 01-12-2015, 02:41 PM
I had a belt chirp for a while. I was able to minimize it so it only did it when cold or damp. Then I changed my tires. I have YET to get it to chirp at all now. I wonder... In order for me to get my wheel into the bead breaker, I had to remove the pulley. I had a 20% chance of putting the pulley back on in the same orientation; chances are I didn't I wonder if that had something to do with it.....
post #4 of 15 (permalink) Old 01-12-2015, 02:50 PM
Lance's Avatar
TIA,
Dan
I've got this, that is the sound of your bike, either happy or sad... it will moan less and hum more if you keep it clean and ride it a lot. You're welcome.
2012 Victory Cross Roads
2003 BMW R1150R
1978 BMW R75/7
1974 BMW R75/5
Lance is offline
post #5 of 15 (permalink) Old 01-12-2015, 03:42 PM
rewindguy's Avatar
Maybe it doesn't know the words? Sorry, my bad! I have a small rub sound at very slow speed, used to have belt chirp big time - I managed to align it out ( not as easy as they claim) chirp hasn't come back!!! I have bike on rack at home and looked at the brake pads / rotor / pulley and everything else under there and I can see no reason for the sound. Humm could be from tire? How many miles on it? I know the Elite E3's I had on my Nomad started to hum and then growl after they were slightly over 1/2 worn.
2014 Cross Country Tour
Goldrush / Black
rewindguy is offline
post #6 of 15 (permalink) Old 01-12-2015, 05:22 PM Thread Starter
45caldan's Avatar
Not lowered.
It has a fairly new E3 on it. Don't think its from the tire.
2010 Cross Roads
Vic HP air filter
Stage 1
Cee Bailey lowers
45caldan is offline
post #7 of 15 (permalink) Old 01-12-2015, 07:38 PM
Motorbikerx's Avatar
Not lowered.
You may need louder pipes.
I rode my Vegas without a helmet for a few miles last year and noticed all sorts of different mechanical sounds.
With the open face helmet and loud exhausts all is sweet
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 15 (permalink) Old 01-12-2015, 07:50 PM
Konga63's Avatar
Good point. I've noticed different "noises" depending on whether or not my face shield is up or down. That being said, have you checked your rear wheel bearing for play?
2007 Ness Jackpot
Konga63 is offline
post #9 of 15 (permalink) Old 01-12-2015, 07:59 PM
depot picker's Avatar
sounds like your belt may be a little too tight. Also, E3s are noisy when cornering.
depot picker is offline
post #10 of 15 (permalink) Old 01-13-2015, 04:53 AM
Have you checked to make sure your wife or girl friend hadn't jumped on with you? .....
just sayin'
PaiN is online now
