Brake light loading-how much - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 01-14-2015, 06:17 AM Thread Starter
Default Brake light loading-how much
I already have a third brake light above stock that has 7 LED's in it. This is fed directly off of the brake light wire that runs under the seat which feeds the stock XC brake light. I want to add additional lights back there-looking at Hyperlites Flashing 8 LED universal kit (http://www.hyperlites.com/moddf.html).
I am wondering about how much electrical load you can put on that line that feeds the rear brake light. The LED control module for Victory has some kind of load limit, probably pretty low since the rear lights are LED, and I do not want to put too much on that wire. The wire appears to be 20/22AWG and I do not want to overload it.
Has anyone had any issues with wire problems back there due to overloading?
Thanks.
-Scott K.
Virginia Beach, VA 23462
U.S. Navy, Nuc CWO, Submarines!!!
Upgraded from my 2013 Red Cross Country:
Red '17 Cross Country
Tank/Fairing Pinstripes by Brian Kite Pinstriping
HotVic exhaust
Victory Beveled Rider/Pass Floorboards
Victory Beveled Clutch/Brake/Heel Shifter Operators
Black Brake/Clutch Levers
Lloydz timing +4
Witchdoctor Red Braided Spark Plug Wires
Witchdoctor: relocated ignition key, small insert
Backrest
Luggage rack
Tour windshield
Vic oil dipstick with thermometer
sltpkirkland is offline
post #2 of 9 (permalink) Old 01-14-2015, 07:24 AM
I don't think you will have a problem. As noted in my signature, I have the Custom Dynamics brake/ tail light license frame and 8 LED Hyper-Lites(brake only). And about 3 months ago added the Kuryakyn Sabertooth lights. No blown fuses and no indication of overheating of the brake wires in the wire loom that feeds the rear tail light area.
2015 XCT Two Tone White/Gray
Ultimate Seat & Backrest
Custom Dynamics Non-Sequential License Plate Frame
Hyper-Lites
Kuryakyn #4178 Windshield Bag
Victory Bag Guards
Custom Dynamic Cool Magic Bullet LED Running Lights
+2" Back Bars
Victory Highway Pegs #2874837 & Z-Bracket
Kuryakyn Sabertooth LED's
Traded for a 2015 Cross Country Tour on 8-31-15
Previous bike was a 2010 Victory Cross Country-Midnight Cherry, had 54,xxx+ trouble free miles. Just needed a change & got a great deal.
rdeerx is offline
post #3 of 9 (permalink) Old 01-14-2015, 07:35 AM Thread Starter
rdeerx;
Sabertooth lights: first I had heard of those. They are really sharp looking. As far as the wires going to the saddlebags to power them. How are they routed and are there quick connects to remove bags? It says "plug n play" to install them, what does that really mean?
Thanks.
-Scott K.
HotVic exhaust
Lloydz timing +4
Backrest
Luggage rack
Tour windshield
post #4 of 9 (permalink) Old 01-14-2015, 09:09 AM
wspollack's Avatar
Originally Posted by sltpkirkland View Post
rdeerx;
Thanks.
-Scott K.
I haven't purchased the Sabertooth lights, but I'm thinking about it. In any case, Witchdoctors has a nice video on the install, here: https://www.youtube.com/watch?v=8mt0dEqhwRc .
Re wire sizes, I think Vic doesn't care much about them. Have you ever looked at the wires that power the dash outlet, for instance? Tiny, and that thing's fused for 20 amps.
Cheers,
Bill P.
wspollack is offline
post #5 of 9 (permalink) Old 01-14-2015, 03:05 PM
The Sabertooths have a male/female plug that plugs into the trunk plug under the left side cover. For those that have a trunk, that lighting is retained. Off that are two leads, one for the left and right Sabertooth lights. they are plug and play with connectors that run to the bags and Sabertooth lights. Watch the Witch Doctors video, that pretty much describes it all.
Hyper-Lites
Victory Bag Guards
+2" Back Bars
rdeerx is offline
post #6 of 9 (permalink) Old 01-14-2015, 05:54 PM Thread Starter
I watched the video after the other post. Really good video and pretty easy install. No one has the black ones in stock. I will probably go with hyper lites.
Thanks.
-Scott K.
HotVic exhaust
Lloydz timing +4
Backrest
Luggage rack
Tour windshield
post #7 of 9 (permalink) Old 01-15-2015, 07:10 AM
To my knowledge, Kuryakyn makes them in chrome only. Witchdoctors was painting them black for resale.
Hyper-Lites
Victory Bag Guards
+2" Back Bars
rdeerx is offline
post #8 of 9 (permalink) Old 01-15-2015, 09:05 AM Thread Starter
rdeerx;
-Your signature lists Kury #4178 Windshield Bag. I have the same bag installed. How did you attach it? Any pics?
-You also list SRVT 2+ handlebars. SRVT? I do not believe I have heard of those. I am assuming 2+ means 2 inch extensions toward the rider.
-Scott K.
HotVic exhaust
Lloydz timing +4
Backrest
Luggage rack
Tour windshield
post #9 of 9 (permalink) Old 01-15-2015, 10:27 AM
The windshield bag has a firm plastic backing. I took out the top 2 windshield screws, loosened the bottom 2. Slide it between the windshield and black windshield brackets, use a awl or center punch and locate the 2 top holes, take out and drill it out. Put it back on and tighten down the windshield screws.
SRVT +2 bars were produced by Santa Rosa V-twin. I don't believe they make them anymore. Victory and some other after market suppliers make them now.
Hyper-Lites
Victory Bag Guards
+2" Back Bars
rdeerx is offline
