Shorten my OEM side stand? - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 01-24-2015, 10:48 AM Thread Starter
Default Shorten my OEM side stand?
On my XCT
I installed an adj lowering link and need a bit more lean on the stand.
I'm thinking I'd make a pair of cuts at 45 degree angle mid-shaft and put a heavy bevel on the ends and have someone TIG it back up. Then dress the welds myself if needed and hit with a rattle can.
Tigging would run me about $30 as opposed to $ 140 for the WD shorty stand. And I could dictate the finished length. I only lowered the bike an inch. I know WD says a shorty stand isn't needed but my bike def needs to lean a bit more.
I don't know if the bar is mild steel or 4140 or other alloy.
Anyone done this?
MMGUT is offline
post #2 of 19 (permalink) Old 01-24-2015, 11:09 AM
dtmmil's Avatar
huh, i run my stock stand with 2" drop, no issues, have to watch where i park at times but thats it.
ive shortened stock stands on other bikes but not this one, it wont take much shortening of it to lean more. some have just taken the rubber pad off the bottom, but that also acts as a cushion i believe when its up
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 19 (permalink) Old 01-24-2015, 11:28 AM
don't use any heat of any kind on the stand. It will weaken steel and fail on you one day.
Find a bike shop or some with a press and bend the stand. Lay the stand across two steel block and bend in the middle. Is the best way.
Not your bike but this trick works great
https://www.youtube.com/watch?v=HzJf2PRTJH0
post #4 of 19 (permalink) Old 01-24-2015, 10:08 PM
infamous_6969's Avatar
Witchdoctors sells a shortened kickstand.
Bike is sold
infamous_6969 is offline
post #5 of 19 (permalink) Old 01-26-2015, 08:41 AM
My stock stand bent on it's own on my XCT, I would not do anything to weaken the stock stand. My bike is stock height too.
2012 Victory Cross Country Tour, Sunset Red.
Parts added to make her louder, faster and more mine.
Stage 1 filter and pipes, Lloydz VFIII & ATW.
Clearwater Darla, LED GLO, emergency lights and siren.
Bushtec hitch and harness, Kompact Kamp trailer.
ChuglyXJ is offline
post #6 of 19 (permalink) Old 01-26-2015, 08:59 AM
I have run the stock stand since lowering the bike 1" when it was new. No issues of any kind.
All of my friends that lowered the bike and changed the kickstand have gone back to stock.
YMMV
Every day is a good day to ride. Some days are just better than others.
2010 Cross Country
Vic Performance filter, D&D, ATW, VFC III
2006 Vegas (sold)
2003 Shadow 1100C (sold)
Various other bikes all the way back to 1968.
BCVR LC#35
rocketo is offline
post #7 of 19 (permalink) Old 01-26-2015, 10:49 AM
Good-One67's Avatar
If you are dead set on a shorter kickstand, I have one. I thought i would need it because i was initally planning on lowering further than where I ended up. Brand new never bolted it on. $40 plus shipping . I wouldn't try heating or bending personally on stock one for the simple "what if" situation is not gonna be very pretty if it does fail.
2013 Cross Country, RJC exhaust, Lloyd's Filter, Timing wheel, PCV, Adjustable Rear lowering link, Goody's front lowers. NW New Mexico
Good-One67 is offline
post #8 of 19 (permalink) Old 01-26-2015, 11:10 AM Thread Starter
Sent you a PM
thanks
[QUOTE=Good-One67;1318194]If you are dead set on a shorter kickstand, I have one. I thought i would need it because i was initally planning on lowering further than where I ended up. Brand new never bolted it on. $40 plus shipping . I wouldn't try heating or bending personally on stock one for the simple "what if" situation is not gonna be very pretty if it does fail.[/Q
MMGUT is offline
post #9 of 19 (permalink) Old 02-14-2015, 10:39 PM Thread Starter
Sincere thanks to Good-One67 for a killer deal on the WD short stand. I finally got it installed today and the lean is now perfect.
My XCT definitely needed it.
It's actually a pretty easy switch out with the bike jacked up a foot or so.
MMGUT is offline
post #10 of 19 (permalink) Old 02-16-2015, 11:14 AM
Good-One67's Avatar
Your welcome, glad it all worked out the way you needed. Ride safe!
