Forward running lights? - Victory Forums - Victory Motorcycle Forum
 3Likes
post #1 of 72 (permalink) Old 01-27-2015, 05:59 AM Thread Starter
Default Forward running lights?
Is there any way to turn on the XC's front turn signals to act as running lights?
I've never liked that the XC only has the headlight as forward lighting, form time to time I think about adding runners. For some reason this morning I thought of this question.
thanks
PaiN is online now
post #2 of 72 (permalink) Old 01-27-2015, 07:32 AM
wspollack's Avatar
thanks
If there is a way, my guess is that you'll have to figure it out, and it won't be easy, i.e., you'll be on the bleeding edge.
I agree that bikes should have running lights in the front:
1) I had a 650 Burgman for five years, and it used incandescent bulbs for turn signals up front. A bunch of us on a Burger forum got together, and (like the rest) I wound up swapping out the bulb sockets, adding a wire, and replacing the single-filament bulbs with double-filament ones. Voila: running lights!
2) On my XCT, I addressed the problem by adding Rivco mirrors with built-in LEDs (running- and turn-signal amber in the front, and turn-signal red on the rear-facing side). I describe this process in agonizing detail in a write-up on my web site: http://www.billanddot.com/adding-rivco-led-mirrors.html
During the course of that work, I discovered that the ECM is super-fussy about voltages or resistance or something, in terms of the turn signals. I wound up using a trailer isolator just to drive the LEDs on the mirrors.
I've also experimented -- without success -- with CustomLED's Blinker Genies ( http://www.customled.com/products/blinker-genie ).
Besides the ECM's being a fuss-budget, I think the problem is that the stock LEDs are "overdriven" to achieve high brightness. I read about this somewhere -- I think someplace on CustomLED's site (but I can't find it now).
Another possible solution is just adding running lights, i.e., leaving the stock signals alone. You might add something such as the Photon Blasters, for instance: http://www.lights.skenedesign.com/PB_Features.shtml
But I certainly agree that it seems a waste to have the bright stock LEDs in the turn signals just sitting out there most of time, not doing anything (just as it was on the Big Burger, with its bulbs... which at least I could do something about).
Cheers,
Bill P.
wspollack is offline
post #3 of 72 (permalink) Old 01-27-2015, 07:56 AM Thread Starter
I saw your write up on the Rivco's when I was looking for info this "issue". I could add running lights but I wouldn't want them or the wiring on the forks or highway bars. I had the thought of attaching LEDs to the turn signal arms, then running the wiring back through the body following the turn signal wires but I'm afraid a steady-on light that close to the turn signal might confuse drivers when I'm signaling.
PaiN is online now
post #4 of 72 (permalink) Old 01-27-2015, 08:12 AM
wspollack's Avatar
Yep, you have a good point, about lights next to lights.
In addition to the Rivcos (which I think are nice, because you get extra turn signals up high, which I think could be helpful for cagers not paying attention), I have Motolights on the forks for conspicuity (I hardly ever ride at night) and the CustomLED flasher for the trunk's brake light.
But, yeah, it still irks me that those stock LEDs seem wasted up front. If you figure out how to make them into running lights, please report back here.
Cheers,
Bill P.
post #5 of 72 (permalink) Old 01-27-2015, 08:20 AM
I'm replacing mine with ones off my Suzuki. It will have a white led running light. When the turn signal is turned on, the middle part flashes amber and the white ring shuts off.
vcc14 is offline
post #6 of 72 (permalink) Old 01-27-2015, 08:24 AM Thread Starter
You'll definitely have to put up a "how to and with what" on this project.
PaiN is online now
post #7 of 72 (permalink) Old 01-27-2015, 08:29 AM
I'd be interested as well
post #8 of 72 (permalink) Old 01-27-2015, 08:36 AM
Would it be too tacky to just stick some additional orange LED strips on top of, or under, the existing turn signals? That would be quite cheap and easy...
post #9 of 72 (permalink) Old 01-27-2015, 11:24 AM
I too wanted to find a way to make running lights out of my front signals, but kept hitting dead ends. So I went with Clearwater Darlas--gawdawful bright (2,000 lumens) and bike specific mounting hardware onto the lower side cowls, at the bottom of the crash bars. That makes for a very noticeable triangle of light. They are on all the time--100% when on high beam and when on low, they are at whatever you dial the brightness to be. Not cheap, but extremely high quality.
https://www.clearwaterlights.com//
madesertrat likes this.
post #10 of 72 (permalink) Old 01-27-2015, 11:42 AM
slickvic's Avatar
I thought the same Broggy. The brightness of the turn signals when activated should still be noticed while the LED's mounted under the light stayed lit. I did see a nice custom look on an HD batwing fairing where individual LED lights were carefully drilled and spaced into the front of the fairing. Similar to the Kuryakyn Fairing Brows for HD. Pisses me off that they only offer a piece of shit chrome brow (no lights) for our XC fairings. Are we listening Kuryakyn ?????
A friend I ride with just replaced the turn signals on his SG with the type that are LED white while running then a separate amber ring lights for signal operation shutting off the white ring. They are an HD piece mimicking the factory lights and housings with smoked lenses. Great look!
Are we listening Polaris ??????
slickvic is offline
