road trip, belt tightening - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-08-2012, 11:43 AM Thread Starter
EraserX33's Avatar
Default road trip, belt tightening
Hey all, I'm currently on a road trip and having an issue with my belt tightening up after about an hour and stsrting to make noise. When I check it its clearly too tight. After letting it sit over night though it loosens up and is wjthin specs. Is this normal, should I set it while hot? Never experienced this before. Ill chr k back for any replies after I get to another spot with connectivity.
Thanks! ( sorry for typos from my phone)
Darrell,
2011 Cross Country, Blue, 1" drop, D&D's, 21", raked tree, RF amp and HCX 6.5's
EraserX33 is offline
post #2 of 8 (permalink) Old 06-08-2012, 11:58 AM
kevinx's Avatar
Belt tension is measured cold for that very reason. Cold tension is like 32mm under 10lb of force. That is pretty darn loose
kevinx is offline
post #3 of 8 (permalink) Old 06-08-2012, 12:39 PM
kingslyzissou's Avatar
I noticed Eraser's bike is lowered. FWIW...the Vegas manual says the deflection spec is different for a lowered model. Doesn't say what it is though . Can this consideration be made for X bikes as well?
2012 vegas 8ball
kingslyzissou is offline
post #4 of 8 (permalink) Old 06-08-2012, 09:18 PM Thread Starter
EraserX33's Avatar
Thanks guys. Currently on a 11k, 30 day bike trip. Belt didn't make any noise before yesterday but it didn't stsrt getting hot till then either so maybe the extra 30 degrees was just enough to have it start howling at me. I will check it in the morning when its cool out. I thought i set it to 32mm but clearly I didn't. It certainly needs to be loosened up. I don't have my manual with me and I cNt remember, is that checked on the ground or with the bike lifted so the wheel is hanging?
Thanks for the replies. And sorry for the typos from my phone
Darrell,
post #5 of 8 (permalink) Old 06-08-2012, 10:16 PM
The belt is checked on the ground.
If it is getting tighter, check for centered (square in swingarm) rear tire. If it is square, then I would loosen just a bit. Too tight is bad.
orbiker is offline
post #6 of 8 (permalink) Old 06-08-2012, 10:18 PM
And where are you on your trip???
Are you writing a ride report while traveling (with PICS)???
orbiker is offline
post #7 of 8 (permalink) Old 06-08-2012, 11:34 PM
I hate to be contrary but my manual clearly states that the wheel be hanging free.....also check when cool and dry
2012 CRLE
mtsiview is offline
post #8 of 8 (permalink) Old 06-30-2012, 08:32 AM
ashmostro's Avatar
And, isn't it 32 *Hz*, not mm? Linear deflection is 10-12mm, right?
2011 Victory Kingpin 8-Ball
Tach / Dual front discs with Vesrah JL pads / Penske shock / S&S Intake / PCV & autotune / RPW Thor exhaust with homemade custom baffle / Tsukayu leather "Strong" bags / Avon Cobra *Radials* / Ness Vegas Peg Conversion / Ness Vegas driver's seat / Custom T-Apes from BR Custom Cycles
ashmostro is offline
