Removing stock heat shields - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 02-01-2015, 04:15 PM Thread Starter
Tinstar5541's Avatar
Default Removing stock heat shields
I'm blacking out my '12 CCT and found that the heat shields at the header connection don't appear to be removable. I could get the shields just before slip-on point off; they are held on with screw clamps.
Can someone let me know how I should go about ceramic coating the shields if I can't get them off?
2012 Cross Country Tour
Lloydz cams
Trioval exhaust
Power commander V
Lloydz precision timing system
Tinstar5541 is offline
post #2 of 18 (permalink) Old 02-01-2015, 05:25 PM
dtmmil's Avatar
they have crimp type hose clamps dont they? if so dremel/die grinder and cut the clamp and use hose clamps to reinstall
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 18 (permalink) Old 02-01-2015, 06:09 PM Thread Starter
They ARE connected via some kind of clamp, but I can't tell if there is anything inside the heat shield which I could use to reattach it after I cut off those clamps.
Lloydz cams
Trioval exhaust
Power commander V
post #4 of 18 (permalink) Old 02-01-2015, 06:15 PM
dtmmil's Avatar
there is a little tab in there that the clamp goes through, so yes cut the band and use hose clamps to put back on
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 18 (permalink) Old 02-01-2015, 06:18 PM
yes there are slots on the inside of the heat shield to slid a hose clamp threw. You can get stainless hose clamps at hardware store cheaper then auto store.
Use a side cutters to cut off the old ones if you have no power grinder
post #6 of 18 (permalink) Old 02-01-2015, 06:40 PM Thread Starter
That's good to know. They are so tight on the pipe that I was afraid they were soldered onto the heat shield.
Lloydz cams
Trioval exhaust
Power commander V
post #7 of 18 (permalink) Old 02-02-2015, 12:17 AM Thread Starter
Success! My Dremel was not working to my satisfaction, so I start chiseling at the clamp crimps. All but two of them snapped without too much beating. I gave the Dremel another try and the last two gave way. Seven 1 3/4 x 3/8" hose clamps and they're ready for reassembly once they get ceramic coated.
Lloydz cams
Trioval exhaust
Power commander V
post #8 of 18 (permalink) Old 02-02-2015, 12:32 AM
dtmmil's Avatar
cool! im getting mine done soon also, just havent decided on the approach yet
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 18 (permalink) Old 02-02-2015, 09:54 AM
saintdruss13's Avatar
I just blacked mine out too and those clamps suck. I cut mine off with a pair of end cutting nippers then just used regular hose clamps.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
post #10 of 18 (permalink) Old 02-02-2015, 06:36 PM
dtmmil's Avatar
what method did you use to black out the shields?
currently bikeless
Hawley MN(sold)
dtmmil is offline
