Help..oil on coil - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 02-07-2015, 08:23 PM Thread Starter
Default Help..oil on coil
I just took the fuel tank off to check the air filter and the top of the ignition coil was covered in what looked to be engine oil. Kind of perplexed as to how it would have gotten there. Any thoughts?
Truckerman is offline
post #2 of 13 (permalink) Old 02-08-2015, 05:39 AM
TNXR's Avatar
Was the bike over filled with oil and it spit it out of the air filter maybe?
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 13 (permalink) Old 02-08-2015, 07:26 AM
Lostintexas's Avatar
TNXR is pretty much on. For some reason these machines didn't read the Owners Manual, and at times like a little less oil.
OK, how it got there. See all those tubes running around under the tank and the front of the seat? Make sure they are clear and connected. Mine spit it out in about the same place when overfilled. It was on the oil stick marks, but dripping oil, and during the time of the porous castings that was concerning. These are vents if you haven't already figured it out, and they can move slightly really giving you headaches if you aren't looking for them.
I took out 4 Oz, and never saw it again, so I made my own "full" mark on the stick and run with it.
Cheers
I ride with the Force.
Lostintexas is offline
post #4 of 13 (permalink) Old 02-08-2015, 07:29 AM Thread Starter
I don't think so. The inside of the tunnel/ frame is dry around the throttle body. Cant imagine that being dry with as much oil was on the coil. I'm not talking a drop or two...the coil was covered on top.
post #5 of 13 (permalink) Old 02-08-2015, 07:31 AM Thread Starter
Thanks for that info..I'll definitely look into that.
post #6 of 13 (permalink) Old 02-08-2015, 07:32 AM
It didn't go from or through the filter box. It came from the vent lines under the tank. Look around, they can be hard to spot the ends.
Even if all is perfect, that is still the exit point and residual can collect. Yea it shouldn't but it is what it is.
post #7 of 13 (permalink) Old 02-08-2015, 01:21 PM
Truckerman
what year and model bike do you have. With out that information you will not get a good answer
post #8 of 13 (permalink) Old 02-08-2015, 02:48 PM Thread Starter
Why? I know what I have for a bike..lol..yeah ,I can be a dumba$$ at times. 2012 cross country tour
post #9 of 13 (permalink) Old 02-08-2015, 03:19 PM
ostbob's Avatar
Funny, I just noticed the same thing, 2012 CCT bike with 9600 miles on it is going to dealer Tuesday so I wrote them this note. And my oil is at the proper line also.
While cleaning the bike the other day I noticed a lot of grease or oil residual above the cheese wedge on the left side (key wedge) on what looks like the coil and can't figure out where it came from. Put 200+ miles on it since and its still clean. Any idea and where it could have came from? Could it of been protective grease from the factory?
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #10 of 13 (permalink) Old 02-08-2015, 04:28 PM
Rebel Biker's Avatar
Truckerman
lol yeah cause the engines on these bikes are very different from model to model.
There is a vent tube that would be different but none the less, same issue.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
