Pull filter - how much oil will I lose? - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 02-07-2015, 08:29 PM Thread Starter
Default Pull filter - how much oil will I lose?
Changing my CCT back to OEM exhaust headers and need to pull the oil filter.
How much oil will I lose when I pull it? WD video says just a couple TBS but I don't know if his oil was already drained.
MMGUT is offline
post #2 of 15 (permalink) Old 02-07-2015, 08:43 PM
Ahoutzer's Avatar
That's right -- maybe a few tablespoons, at most. I did it in late December. My bike was on a level floor, on its side stand.
2012 XCT (Blackbird)
Forged bars & JTD lowers
Stage 1 flash & Tri-ovals
LLoydz ATS @+6*, Air filter, Drop-in cams
VFCIII tuned by KevinX
Madstad with 13-inch shield
Garmin Zumo660
Tri-city Performance floorboard footrests
Heel shifter
Corbin saddle & backrest
Cee Bailey's bag liners
Wolo Badboy horn
KuryAkyn Sabertooth lights
Ahoutzer is online now
post #3 of 15 (permalink) Old 02-08-2015, 10:32 AM
slickvic's Avatar
What aftermarket set up did you have and why are you changing back? Problems with the one you are using? Noisy? just curious.
slickvic is offline
post #4 of 15 (permalink) Old 02-08-2015, 10:37 AM
dtmmil's Avatar
why do you need to pull the filter? i just pulled my stock setup off and never pulled the filter
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 15 (permalink) Old 02-08-2015, 10:53 AM Thread Starter
Bike I bought had a ghetto 2 in 1 mod of OEM where crossover tube was cut and capped and right muffler was completely hollowed.
What a godawful racket. I don't want to pull my front header tube so goal is to install the crossover section with front tube in place = have to pull the filter.
Might not work, but gonna try.
MMGUT is offline
post #6 of 15 (permalink) Old 02-08-2015, 11:00 AM
dtmmil's Avatar
i pulled my complete system, didnt touch the filter, but you may want to loosen the front headpipe, i couldnt quite get the rear pipe off till i loosened it up, it helped. good luck the connection at the front rear headpipe was a pain! shoot a little wd or something on it and lots of wiggling!!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #7 of 15 (permalink) Old 02-08-2015, 11:13 AM
When I pulled my stock pipes off. I took the filter off. It only looses a little oil and I makes life much easier. It only takes a second to pull the filter. It wasn't even enough lost to register on the dipstick. To me working on that exhaust is enough of a hassle to have to work around the filter.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #8 of 15 (permalink) Old 02-08-2015, 12:13 PM
dtmmil's Avatar
gotcha, i didnt even notice if the filter was in the way. mine came off just fine, as far as that goes
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 15 (permalink) Old 02-08-2015, 12:56 PM
Put a 2x4 under back tire and loose none
post #10 of 15 (permalink) Old 02-09-2015, 02:17 PM Thread Starter
Not done with the job yet, but the (2nd hand) replacement center section with crossover is bolted in place. Didn't have to loosen the front flange bolts. It *just* slid into place and had to have the wife do a bit of prying at one point but it's done.
I did apply a very thin film of moly-grease to the slip joints and things slid back together without much trouble.
MMGUT is offline
