XR ticking noise - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 06-17-2012, 04:56 PM Thread Starter
Default XR ticking noise
I have a 2011 XR with an annoying ticking sound, like a valve or lifter knock. It makes my ride sound like a Singer sewing machine. Any thoughts/suggetions appreciated. I had a mech look at it (not a Vic mech,however) and he said nothing to worry about.
Magnus53 is offline
post #2 of 10 (permalink) Old 06-17-2012, 05:22 PM
Is the ticking at start up or at 30 mph or at 70 mph
you have to tell us more if you want help.
How old is your oil or is the oil level low.
post #3 of 10 (permalink) Old 06-17-2012, 07:48 PM
saddlebag's Avatar
I would suggest staying away from fabric stores. Your XR maybe horny and feel the need to breed...
Seriously though, mine made a loud ticking sound the first time I started it after its winter nap. I think its still there a little, but much quieter now. Do you ride often?
2011 Cross Roads
saddlebag is offline
post #4 of 10 (permalink) Old 06-17-2012, 09:18 PM Thread Starter
Default XR ticking
The ticking has always been there since I bought it last September. When I told the salesman at the dealer, he suggested it may just need to break in. The oil level is fine, and I changed it yesterday. I also changed it at 300 miles and at 1200. It now has 2700 on it. The noise manifests itself at cold start and once the oil circulates, it subsides briefly, and when hot at highway speeds it varies with the RPMs. I'm of the opinion it may be a partially blocked oil port, lifter malfunction, or valve adjustment. I'm currently running Amsoil 20w50. I was using their 10w40 before I changed it.
2011 Crossroads
Virginia Beach, VA
Magnus53 is offline
post #5 of 10 (permalink) Old 06-17-2012, 10:50 PM
CrossRoads's Avatar
An aftermarket set of mufflers will make the ticking (sewing) sound go away.
CrossRoads is offline
post #6 of 10 (permalink) Old 06-17-2012, 10:53 PM
ammo_umb's Avatar
You're straddling a large V-Twin and if you aren't used to riding fairing or windshield equipt bikes you will hear a lot of engine noise. The diagnosis is simple:
-If it ticks all the time you're hearing lifters and possibly injectors. This isn't a problem, even cars do it but you wouldn't notice unless you take a ride on top of the engine.
-If it ticks quietly at start up and goes away when slightly warmed up it's an indication of lifter noise that would warrant an adjustment.
-If it clicks loudly at start up and shakes the bike but goes away when slightly warmed up you could be hearing rod bearings which is bad juju.
-If it ticks quietly at start up and doesn't stop until it's warmed all the way up it's probably exhaust gaskets which could be fixed by tightening the bolts on the head pipe flanges.
Mine has done the first example for over 13000 miles and it hasn't chanced from day one.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #7 of 10 (permalink) Old 06-19-2012, 10:11 AM
Mine ticked and made all kind of noise from day one. Couldn,t stand it anymore so i traded it! Vic bikes look nice but their motors need some changes. Way to much engine noise.
2012 Crossroads
bigsid is offline
post #8 of 10 (permalink) Old 06-19-2012, 11:35 AM
A set of D&D`s will take care of it!
2011 BLUE XC
Tour trunk
D&D VFC III
homebrew is offline
post #9 of 10 (permalink) Old 06-19-2012, 09:08 PM
AZXCNESS's Avatar
My ticking noise was key ring banging on cheese wedge. Drove me nuts till I figured it out.
2011 XC NESS #254
AZXCNESS is offline
post #10 of 10 (permalink) Old 06-20-2012, 12:21 PM
Yep, I was on a trip pretty much in the middle of nowhere,05
tour
cruiser, my noise was the same, cheese wedge. Got rid of the ring and used a tie wrap instead, problem solved. Think the Vic is noisey--try a Kawasaki, now they were loud, never a issue, just the way the motors sounded.
2008 Vision Black gone 2005 TC- Sold
1963 Triumph Bonneville,not sure on color-be awhile
1983 XS 650 Custom Midnight Gold
2007 Ural Patrol Black-Sold
2011 Cross Country White and Silver
2012 Cross Country Red and Silver--Hers
A bunch of other bikes over the years, mostly all good
Life is short, eat dessert first, simple enough.
N/E Georgia and my garage
Shuffles is offline
