How to hook up heated seat on XC? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 02-23-2015, 01:19 PM Thread Starter
Default How to hook up heated seat on XC?
So I'm going to be getting a Russell seat. I'm considering whether to have them put heat in it. Has anyone added a Russell heated seat to a Cross Country that didn't have factory heated seats? How do you hook up the wiring? Does the bike already have wiring to plug into or is this a full custom job to tap off the battery and add a relay?
Sounds like they offer either switches on the side of the seat or you can buy and use a factory switch, though it isn't clear how easy that is to install.
Thanks,
Rob
2012 Victory Cross Country - Imperial Blue
2008 Honda CBR1000RR - Winning Red
2003 Honda VTX 1800C - Illusion Blue
BigBlue is offline
post #2 of 9 (permalink) Old 02-23-2015, 02:44 PM
soofle616's Avatar
my cross roads did not have heated seats but it was prewired for it. Remove the old seat and somewhere under the rear fender is a 2 position harness that is used with the factory heated seats. Pull that out, plug it in and you're good to go. Took me maybe 5 minutes to get it all done when I put an OE touring seat on my bike.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #3 of 9 (permalink) Old 02-23-2015, 02:51 PM Thread Starter
Thanks. So what did you use for the on/off switch?
Rob
BigBlue is offline
post #4 of 9 (permalink) Old 02-23-2015, 03:42 PM
soofle616's Avatar
Rob
On the OE seat it's built into the seat. Kind of a pain actually because you can't reach it while on the bike. The harness itself is switched 12v but once the bike is on the harness is on so you don't have an option to turn it off unless you add something. If you do have a heated seat build for you either plan on tapping into the power wires that are already on the bike to add a switch or ask the builder to add the switches directly into the seat.
2013 Cross Roads LE
post #5 of 9 (permalink) Old 02-23-2015, 03:49 PM Thread Starter
Russell will put them directly in the seat, normally, or they will leave them out for you to mount. I thought there was a dash switch for the CCT heated seat, but I may be mistaken.
Thanks,
Rob
BigBlue is offline
post #6 of 9 (permalink) Old 02-23-2015, 03:56 PM
DirtyDan's Avatar
The switches for the xct heated seat are on the left side of the seat. The dash switch is for the heated grips.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #7 of 9 (permalink) Old 02-23-2015, 04:06 PM Thread Starter
Thanks for clarifying that. Makes things easier to not have to procure and install a dash switch.
Rob
BigBlue is offline
post #8 of 9 (permalink) Old 02-23-2015, 07:02 PM
Barryj2065's Avatar
Anyone know if the 2011 Cross Country is already pre wired for a heated seat?
Barryj2065 is offline
post #9 of 9 (permalink) Old 02-24-2015, 01:54 PM
HowardGNelson's Avatar
Well the 2010 is and it was the first ones so I would think the 11s are
2012 XCT Sunset Red - D&D's, Lloydz filter, ATS +4, Clearwater Krista's, Fusion LED kit, Rusty Jones single din, Sony head unit, PCV, BAB Tank Lift, BAB 1/4 Turn, Kenwood 400x4 amp, Soundstream 1000x4 amp, Focal 6.5s, DS18 tweeters, Polk Audio DSi5.25s, Rick Fairless mini apes
RIP my 2010 Victory XC-Skull bike (Totaled 10/21/16)
07 Jackpot Premium - white w/ flames(SOLD)
**Stop saying "how dumb can you be", people seem to be taking it as a challenge**
HowardGNelson is offline
