horn mount - Victory Forums - Victory Motorcycle Forum
post #1 of 24 (permalink) Old 06-21-2012, 08:34 AM Thread Starter
depot picker's Avatar
Default horn mount
I have my Wolo Bad Boy horn. Looks just like a Stebel. Looking for a mount point easier than those mentioned, two come to mind.
The first is to reinforce the floor of the left glove box and mount it inside the lower, under the glove box, partially exposed. The second option is to fabricate a simple triangle bracket and use the two bolts on the right side trunk support to mount the bracket. Either would be way easier than the other methods described.
Can anyone talk me out of it?
Dave
depot picker is online now
post #2 of 24 (permalink) Old 06-21-2012, 09:15 AM
PhilC64's Avatar
I separated the horn from the compressor and then mounted the horn behind the chin fairing. The compressor I mounted on the rear frame behind the rear fender. I then ran black tubing to the front to the horn portion.
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #3 of 24 (permalink) Old 06-21-2012, 09:21 AM Thread Starter
I'll have to look at separating them. It leads to a bunch of new options.
post #4 of 24 (permalink) Old 06-21-2012, 09:25 AM
irv
irv's Avatar
are there other options that would just sound better than
stock? do all cr and cc's sound like stangling a goat. even
my vtx sounded better. "BAAAAAAA"--irv
have never heard the air horns. are they loud enough to
scare semis?
mph faster].
irv is offline
post #5 of 24 (permalink) Old 06-21-2012, 09:29 AM
PhilC64's Avatar
I used a Dremel to cut off the plastic band that holds the horn to the compressor and slid it off. I then clamped the tubing to the compressor. On the horn segment I fit a brass nipple and epoxied it in place.
You can also get the Wolo Model 400 Airmite2. The horns are separated already. http://www.wolo-mfg.com/air.htm
2010 XR - Road toy
PhilC64 is offline
post #6 of 24 (permalink) Old 06-21-2012, 09:31 AM
PhilC64's Avatar
scare semis?
I found a horn from a 58 Buick that worked. Other than that you'll just have to keep choking the goat.
2010 XR - Road toy
PhilC64 is offline
post #7 of 24 (permalink) Old 06-21-2012, 09:35 AM
ammo_umb's Avatar
Irv,
You can buy a standard replacement horn at just about any auto parts store. They can be found in high, low, and high/low tones and will fit in the factory location. I went with the high tone and it's about twice as loud as the original.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #8 of 24 (permalink) Old 06-21-2012, 09:52 AM
CrossRoads's Avatar
My Stebel air horn's been under the rear fender for about a year now - blasts nice and loud, and has worked without a hitch.
To me, having the horn out of plain view was important - but you seem to be wanting to show it off - just make sure you figure out how to conceal its wires. Also it does not like moisture, so riding through rain with the horn exposed might spell disaster.
CrossRoads is offline
post #9 of 24 (permalink) Old 06-21-2012, 09:57 AM Thread Starter
I'm not sure what model Wolo I have. Looked like I'd need to remove the outer covers to separate them. Sure would make it easier to locate the halves than the whole thing in one place.
post #10 of 24 (permalink) Old 06-21-2012, 10:40 AM
irv
irv's Avatar
i have no reply that i can type to that one
mph faster].
irv is offline
