Replacement brake pedals - How safe? - Victory Forums - Victory Motorcycle Forum
post #1 of 22 (permalink) Old 02-26-2015, 09:38 AM Thread Starter
Default Replacement brake pedals - How safe?
I'd like to get an aftermarket rear brake pedal for my XC. The stock peg is a bit small and ugly. However, the aftermarket pedals (like these from Witch Doctors) typically involve drilling out the threads in your brake lever and installing the new pedal with a screw.
That looks a bit frail to me. I'd think in a panic stop it wouldn't be hard to jam the pedal hard and break off the small screw holding the pedal on. Has anyone had pedal failures like this? Or am I worrying about nothing? I suppose I could buy a higher-grade bolt to use instead of the one that comes with the pedal.
Thanks,
Rob
2012 Victory Cross Country - Imperial Blue
2008 Honda CBR1000RR - Winning Red
2003 Honda VTX 1800C - Illusion Blue
BigBlue is offline
post #2 of 22 (permalink) Old 02-26-2015, 10:07 AM
Put this on mine and I'm liking it!
http://www.ebay.com/itm/Victory-Visi...a42de4&vxp=mtr
Mark-B is offline
post #3 of 22 (permalink) Old 02-26-2015, 10:11 AM Thread Starter
How does that one attach?
BigBlue is offline
post #4 of 22 (permalink) Old 02-26-2015, 10:13 AM
luvmyride's Avatar
I've never heard a bad thing about Dain's brake pedal (eBay ad above). You can also shop on his website
http://www.victorybrakepedal.com/
I don't know if he is a member here, but on "another" forum I know he gives a discount
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #5 of 22 (permalink) Old 02-26-2015, 10:52 AM
Lostintexas's Avatar
I use these. http://www.kuryakyn.com/products/920...ift-brake-pegs Have them for shift and brake, they bolt straight in to the OEM threads and are a bit longer than the OEM.
They meet my needs, match, go well with the bike and satisfy a nice feel that I got used to with the round pegs. Yea many don't like the round, but I do, FWIW.
Happy shopping
I ride with the Force.
Lostintexas is offline
post #6 of 22 (permalink) Old 02-26-2015, 12:21 PM
Originally Posted by Lostintexas View Post
I have the same ones, for brake and shift. Easy to install, look good and are durable.
post #7 of 22 (permalink) Old 02-26-2015, 12:59 PM
luvmyride's Avatar
Happy shopping
Wow, those are cheap! I may have to give them a try for only $40. They will match my grips pretty well too.
Thanks for the heads up...
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
VicBaggers:
+6 degree trees
Bag fillers
Tarzanz +2" bars
post #8 of 22 (permalink) Old 02-26-2015, 01:01 PM
soofle616's Avatar
5mm allen to tighten the screw means it's most likely an M8
Given that the bolt is more or less supported for it's entire length you'd have to significantly stretch the metal before it would even have room to bend. I wouldn't hesitate for a second to put that on my bike if that's what I wanted.
As an anecdotal piece of evidence, I did something similar on my old SV650 back in the day. Tipped the bike over and broke off the toe piece on the shift lever. Drilled it out and put a 1/4" bolt through with a nut to secure it. Left it that way for a year before I remembered and bought a new lever. That bike had a much thinner section lever made from visibly porous cast aluminum. The XR/XC has a much thicker lever that would hold up a lot better AND you're talking about a thicker bolt (1/4" is about 6mm compared to 8)
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #9 of 22 (permalink) Old 02-26-2015, 01:55 PM Thread Starter
Happy shopping
Thanks for the tip. I like that they bolt right up without having to drill my levers. These go with my Kury grips and highway pegs, so I may have to give them a try. They can be had for $17 each on Amazon with free shipping.
Rob
BigBlue is offline
post #10 of 22 (permalink) Old 02-26-2015, 02:15 PM
Rob
LOL that is where I got mine. On a fast and dirty search one goes to the source since I couldn't remember the part number.
Like others, I have never heard a bad thing about the "Dain" pedals, and his service after the sale seems to be stellar from the reading I've done.
I wanted something after the rubber fell off the OEM, and these were being tossed on a board, maybe this one, so I gave it a whirl. They are a small compliment and seem to get the job done. The extra length is also a nice touch.
One note for ease of install. After you muscle the OEM pegs off, clean the threads good and put on your own lock tight. Take your time and watch the position of the allen wrench. The heads are adequate, but shallow and could strip if you are being rough.
Cheers.
