16mm front axle allen wrench - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 03-04-2015, 01:10 PM Thread Starter
Default 16mm front axle allen wrench
I had a heck of a time finding a 16mm allen wrench for the front axle. Most bike parts stores only have a 17, 19, etc. After an hour or so of searching I found a 16mm at Grainger for 13.00.
Just patiently waiting on my rim to arrive.
Blade15 is offline
post #2 of 18 (permalink) Old 03-04-2015, 01:45 PM
Harbor Freight, got a whole set for about 11 bucks.
Draper is offline
post #3 of 18 (permalink) Old 03-04-2015, 02:44 PM
Is it possible to just use a large metric bolt with a 16 mm head and then jam two nuts together on the threads to provide a place to turn? Even better would be to make a quick weld on the nuts to the threads. This is what I use for the axle of my wife's VTX 1300.
Another option is a 16 mm coupling nut although this might be hard to find. If you did find one, they would likely be cheap. They are long enough that you could get one end into the axle hole and put a socket on the other end.
G'day,
Vinish
Vinish is offline
post #4 of 18 (permalink) Old 03-04-2015, 02:46 PM
Pauljp's Avatar
Others had the same difficulty finding the proper size, so they went with a coupler nut instead.
You can see their post here.
I think that is the way I am going to go, but I hear they changed the newer years to a 14mm so it might be easier to find.
Opps... Vinish posted the same thing before me.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #5 of 18 (permalink) Old 03-04-2015, 02:47 PM
dtmmil's Avatar
5/8" is the same
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #6 of 18 (permalink) Old 03-04-2015, 02:58 PM
Mark-B is offline
post #7 of 18 (permalink) Old 03-04-2015, 11:26 PM
PhilC64's Avatar
Originally Posted by dtmmil View Post
5/8" is the same
5/8th's, 16mm, whatever it takes.
http://www.sosmath.com/tables/sae/sae.html
2015 XCT - Flying lounge chair
PCV, ATS +4, Lloydz filter, VM1-HPT cams, and Freedom True Duals.
2004 King Pin - 100 cid Big Bore, Ness Intake, Victory Performance Exhaust
2010 XR - Road toy
PCV, ATS +4, Lloydz filter, VM1-DR cams, and Freedom True Duals - traded
Cam Swap write up for X Series bikes:
https://docs.google.com/open?id=0B95...YW1XVXFpeU9fUQ
PhilC64 is offline
post #8 of 18 (permalink) Old 03-05-2015, 12:58 AM
Put a bolt in it for your socket to grab on and you'll have your tool.
http://www.homedepot.com/p/Simpson-S...pler+nut+5%2F8
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #9 of 18 (permalink) Old 03-05-2015, 06:48 AM
Why can't you just use a 5/8" or 16 mm socket to "grab" the portion of the coupling nut that is sticking out of the axle hole? The coupling nut is long enough that it could stick into a bottomless axle hole deep enough and still have plenty sticking out for the socket or wrench to "grab".
G'day,
Vinish
Vinish is offline
post #10 of 18 (permalink) Old 03-05-2015, 06:48 AM
a 16mm hex bit, or 5/8ths hex bit works.
Someone was very ingenious here and bought a 5/8 coupling nut for less than $2 and it works fine.
