where is the "marketplace" section? (air shock) - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 03-06-2015, 11:14 AM Thread Starter
sheets's Avatar
Default where is the "marketplace" section? (air shock)
Searched archive for threads addressing the air shock (CCT). Was looking at threads... somebody made up a airline extension and routed it forward so the fitting was accessible without removing the side cover. Anybody have experience with relocating the schrader valve connection. How long of hose? I've got the little Fox hand pump. Seems it takes about 1740 (+/-) strokes to make a measurable difference in pressure. Yesterday I purchased a 12 volt mini air pump with built in gauge - 100 psi max pressure - to see if that works better than the hand pump. Will experiment later today.
Thoughts and opinions requested. Thanks. Dennis
2014 XCT - blue/silver - 11" Madstad windscreen - hyd clutch - Black LED headlight -
Vic backrest - Vic short antenna - Clearwater fender-mount LED driving lights -
Vic Tri-Oval mufflers - Lloydz air filter - PC/V - Dyno tuned @ RPM, Yuba City, CA. -
sheets is offline
post #2 of 21 (permalink) Old 03-06-2015, 11:26 AM
It sounds like something is either wrong with your pump or it isn't getting a good connection to the valve. The shocks pump up quick with the hand pump usually.
The marketplace is called the "classifieds". You can see the link at the top left of the Active Topics page. Probably other pages too.
post #3 of 21 (permalink) Old 03-06-2015, 11:32 AM Thread Starter
sheets's Avatar
Took my hand pump to three different bicycle shops yesterday. I asked each one to test my pump. They all hooked it to a bike with air shock (much smaller volume). They said the pump works as designed. I don't have any other motorcycle air shock to compare pump function so I don't know what "normal" function is when it comes to inflating the Vic shock with hand pump. Thanks for the feedback.
sheets is offline
post #4 of 21 (permalink) Old 03-06-2015, 12:37 PM
Blaque's Avatar
I had the same problem you have. I had the $70 vic pump and I would pump that thing 20 times and would only get about 5 psi out of it and then I would lose that 5 psi unscrewing it from the valve. Used my sons $4 bicycle pump and 2 or 3 pumps and Im up to 45 psi. Works great and I took the vic pump back to the dealer. Im actually glad it didnt work.
2014 victory cross country
2012 victory jackpot.... traded for XC
1999 suzuki hayabusa... sold
1994 cbr 1000 (1st bike!).sold
Blaque is offline
post #5 of 21 (permalink) Old 03-06-2015, 04:05 PM
ostbob's Avatar
Contact member Wspollack he did a nice schrader relocate.
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #6 of 21 (permalink) Old 03-07-2015, 12:31 AM
toejam's Avatar
Luvmyride did that mod, looks good and is actually quite handy without having to remove the side cover every time.
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #7 of 21 (permalink) Old 03-07-2015, 11:11 AM Thread Starter
sheets's Avatar
Question
I guess I need a lesson on how to contact folks on here. How do you find member names or alias so one can send a PM.
I tested the 12v mini air compressor on a bicycle tire. It works quite well. 0 to 50 psi in about a minute +/- for that amount of volume.
A couple days before; when using the Fox pump, and after considerable effort, the gauge would read about 25-30 . I put a different dial gauge with 10" hose (?) and would read about 50. I didn't really know what the pressure was. Before I stuck the 12v mini on there I checked the pressure with the simple old school pencil style gauge. It reads 60. Two or three quick checks each read 60. I'm leaving it as is for now. Will check the pressure again in a week or so.
sheets is offline
post #8 of 21 (permalink) Old 03-08-2015, 11:38 AM
ostbob's Avatar
if they respond on the site you can click on their names otherwise you'll probably have to ask the site administrator how to contact them.
Bob
Ex-USCG
2012 Victory XCT,
2" pull backs
ostbob is offline
post #9 of 21 (permalink) Old 03-08-2015, 12:08 PM
Click on the persons name and choose "Send a private message to xxxxx".
You can also go into messaging via UserCP and type the persons forum name in to the "To" section. It must be spelled correctly and is case sensitive.
post #10 of 21 (permalink) Old 03-08-2015, 12:49 PM
ammo_umb's Avatar
Click on Victory Cross Country and Cross Roads
Click on Search This Forum
Look for the User Name block
Enter the users name and click submit
Open one of the users posts and click on his name
Click on Send PM
This will get you into the users PM. Draft / submit your message. Once he responds you should get a notification.
Retired USAF, IYAAYAS!
ammo_umb is offline
