Shifting degrades when oil is hot - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 140 (permalink) Old 03-09-2015, 08:53 PM Thread Starter
Default Shifting degrades when oil is hot
My CCT is 2012 with 11,500 miles. Victory oil (kit) has 1000 miles on it. Ambient temps are 54f.
After the engine is has been freeway-running for 1/2 hr or so my shifting starts to degrade, namely the shifts get clunkier and my bike doesn't want to drop down into 1st gear. It will act as though it's bottomed out in N or 2nd and I have to give it a hard tap/kick down into 1st.
Clutch is adjusted properly.
I haven't owned this bike in hot weather and want to get on top of this before it comes.
Ideas?
Thx
MMGUT is offline
post #2 of 140 (permalink) Old 03-09-2015, 09:05 PM
Travis P's Avatar
How fast are you going when trying to get into first? I only shift into first once I am stopped so I am not sure if my XC does this or not.... When I stop I go from 2nd to neutral then once I see the light changing I pull the clutch and tap down to first.
Travis P is offline
post #3 of 140 (permalink) Old 03-09-2015, 09:11 PM Thread Starter
I'd say maybe 5-10 or sometimes 15mph. MSF class guy insisted we be in 1st gear when we came to a stop.
Edjumacate me please
MMGUT is offline
post #4 of 140 (permalink) Old 03-09-2015, 09:38 PM
dtmmil's Avatar
i generally drop to first as im coming to a stop also
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 140 (permalink) Old 03-09-2015, 10:13 PM
Travis P's Avatar
Hmmm... I think we need more opinions.
Travis P is offline
post #6 of 140 (permalink) Old 03-09-2015, 10:32 PM
When coming to a stop, don't shift into 1st over10 mph. I find that most riders are afraid to rev their engines up to proper RPMs for running and shifting, thinking they are going to hurt their engine, but the opposite is true--not revving enough does harm to the engine. Do do not operate your bike under 2200 RPMs and upshift at 3K or above. You can not overrev your engine as there is an ignition cutout at about 5200 RPM. When working really trwisty roads, I'm at 3500 to 4500 RPM. Being at higher RPMs gives you much more throttle control and makes carving more enjoyable. For smoother and quieter shifts, preload the shifter. Also, adjust the shifter lower so that when your boot is under it, most of the slack is taken up.
post #7 of 140 (permalink) Old 03-09-2015, 11:33 PM Thread Starter
Originally Posted by RICZ View Post
When coming to a stop, don't shift into 1st over10 mph. I find that most riders are afraid to rev their engines up to proper RPMs for running and shifting, thinking they are going to hurt their engine, but the opposite is true--not revving enough does harm to the engine. Do do not operate your bike under 2200 RPMs and upshift at 3K or above. You can not overrev your engine as there is an ignition cutout at about 5200 RPM. When working really trwisty roads, I'm at 3500 to 4500 RPM. Being at higher RPMs gives you much more throttle control and makes carving more enjoyable. For smoother and quieter shifts, preload the shifter. Also, adjust the shifter lower so that when your boot is under it, and most of the slack is taken up.
Splain that plz?
MMGUT is offline
post #8 of 140 (permalink) Old 03-09-2015, 11:40 PM
Preloading is applying upward pressure on the shifter (not enough to force a shift) so that when you pull the clutch lever, the shifter slides up into the next gear smoothly and much quieter than if you don't preload.
BTW, I am using Rotella T-6 and liking it very much. No shifting problems and it holds up beyond 7K miles per an oil analysis.
post #9 of 140 (permalink) Old 03-10-2015, 06:04 AM
TNXR's Avatar
It took me nearly a year of riding my XR to figure out what RICZ is talking about when it comes to engine revs. I was used to my last two smaller cc jap bikes that would be screaming at 3k-4k rpms but not the Vic. Once I learned to shift at higher rpms and to hold the bike in a lower gear (usually 3rd) while riding the twisties it became a whole different bike to me.
2011 Cross Roads Sunset Red
TNXR is offline
post #10 of 140 (permalink) Old 03-10-2015, 06:30 AM
BeoBob's Avatar
I have been having the same problem for maybe a year, but it does not happen all the time. The way I can explain the problem is that it takes more force than usual to downshift from 3-2 and 2-1 and there is kind of a crunch feeling... like you stepped on an acorn on concrete. Only happens when the bike is at normal operating temperature.
I find that rev matching helps. That is when you pull the clutch and increase rpms to match what is needed in the next gear down for the speed you are going before changing gears. It doesn't always fix the problem 100% but it sure makes it better.
Here is the strange thing. Sometimes if I park the bike for 5 minutes (like to get gas or whatever) the problem goes away and may not come back for a few days. Sometimes it sticks around for a few days and then will disappear for a week. I cannot find any correlation to old or new oil, ambient temperature, type of riding, traffic conditions, or anything else except it does not have the problem when the bike and oil are cold.
This has been bugging me for a while now. If someone figure out how to fix this problem that would be awesome. Just an explanation of whatís happening would be great.
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
