oil for rear shock? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 03-12-2015, 03:09 PM Thread Starter
catroadman's Avatar
Default oil for rear shock?
Random question here. One of the guys I ride with has a HD. When he goes to lower the air pressure on his rear shock he said the book tells you to add a couple of pumps of air before letting any out to clear any oil out of the line. He ask if my Vic said to do the same thing. I don't recall reading anything about this. Do any of you guys know anything?
Next thought is would it hurt or be a good idea to add some oil (like air tool oil) in the line to allow it to lube the seals inside the shock?
catroadman is offline
post #2 of 12 (permalink) Old 03-12-2015, 06:25 PM
never heard or read that on a h-d. Guess what there saying if there is oil in the line it will push in back in.
Have heard of h-d guys putting in different oil to change the ride
post #3 of 12 (permalink) Old 03-12-2015, 06:32 PM
rhino 2's Avatar
Yes... Before you let air out of an air shock you should pump a few pounds in, Or you'll lose oil.. Also you should be using a NO loss air pump only...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #4 of 12 (permalink) Old 03-12-2015, 06:33 PM Thread Starter
catroadman's Avatar
Anybody ever added oil before?
2011 X-country
post #5 of 12 (permalink) Old 03-13-2015, 05:30 AM
TNXR's Avatar
Never heard of such. Is the HD shock serviceable? The Vic one is not, a one piece unit that has to be replaced when it starts leaking oil (like mine did).
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 12 (permalink) Old 03-14-2015, 06:47 AM Thread Starter
catroadman's Avatar
Think I will take out valve and add a few drops of air tool oil just to line the moving parts inside of shock
2011 X-country
post #7 of 12 (permalink) Old 03-14-2015, 11:36 AM
Why do you want to add oil.
You can bet the oil that's in the shock is heaver then that tool oil your going to add.
Why not put more air in the shock
post #8 of 12 (permalink) Old 03-15-2015, 08:43 AM Thread Starter
catroadman's Avatar
That is what I was trying to figure out is of they was oil already in the shock.
2011 X-country
post #9 of 12 (permalink) Old 03-15-2015, 11:35 AM
Yes there is oil in the shock.
Here is one for all the thinkers.
There is no service intervals for the shock and it goes up and down as much as the front end.
So why do we service the fork oil in the front end and do nothing with the shock.
So is the rear shock superior
post #10 of 12 (permalink) Old 03-15-2015, 12:01 PM Thread Starter
catroadman's Avatar
Guess you service it when it breaks
2011 X-country
