Video of installing an LED headlight - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 03-12-2015, 08:44 PM Thread Starter
Pauljp's Avatar
Default Video of installing an LED headlight
I bought the Victory Beacon LED chrome headlight last fall.
It is still cold in my garage but I couldn't wait any longer and I finally uncovered my baby and gave her a new light.
You can watch my video here.
Let me know what you think.
Thanks
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #2 of 13 (permalink) Old 03-13-2015, 12:57 AM
Thanks
The video is very well done. I have the LED head light arriving next week. I was surprised in the video of the apparent heat sinks or fins on the LED assembly on the back of the lamp.
I thought LED's didn't emit heat?
Draper is offline
post #3 of 13 (permalink) Old 03-13-2015, 06:45 AM Thread Starter
Pauljp's Avatar
It is more for the circuit boards inside.
It does seem excessive for what it is though.
Just like their bikes, built bullet proof
Paul
Pauljp is offline
post #4 of 13 (permalink) Old 03-13-2015, 06:59 AM
LEDs do create heat, especially the more powerful ones used in headlights. That's why they need the heat sink on the back of them.
vcc14 is offline
post #5 of 13 (permalink) Old 03-13-2015, 07:38 AM
soofle616's Avatar
Much like HID bulbs, LED's still create heat, they just create less of it per watt of consumption which means a greater percentage of the power used is converted into light. The problem is that LED's are MUCH more sensitive to heat than halogens or HID's. Anything will burn out if you get it too hot but LED's have less tolerance for excess heat so they burn out easier if you overheat them. In addition, the heat they generate is typically localized to their connections so even though less heat is produced, it can be very localized resulting in much higher actual temperatures even though there is less heat energy in total.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #6 of 13 (permalink) Old 03-13-2015, 08:38 AM
johneswank's Avatar
So I've been waiting for the black LED. I went by the dealer a couple of weeks ago and they had the chrome in stock and of course the salesman tried to tell me there was little to no difference between the black and the chrome. Has anyone seen both of these next to each other? I have a white/black XC so I would like things to match up... especially when forking over $400.
Pearl white
Modified Thrush-stuffed exhaust
Victory beacon LED headlight
VicBaggers tips
RF300 amp, Focal IC 165 6.5" speakers
Lloydz timing wheel +4
Lloydz air filter
Victory Hard Lowers
Victory Trunk
Kuryakn Luggage Rack
PC 5
Dyno
O2's unplugged
Chapel Hill, North Carolina
johneswank is offline
post #7 of 13 (permalink) Old 03-13-2015, 08:45 AM
Travis P's Avatar
The chrome one will not look good on your XC... Chrome light with black headlight trim?
Travis P is offline
post #8 of 13 (permalink) Old 03-13-2015, 08:56 AM
johneswank's Avatar
That's what I thought but the SALESman said that the only part that is black is a the outer plastic lens part that is covered by the headlight bezel anyway.
Can anyone confirm this?
Pearl white
VicBaggers tips
Lloydz air filter
Victory Hard Lowers
Victory Trunk
PC 5
Dyno
O2's unplugged
post #9 of 13 (permalink) Old 03-13-2015, 10:48 AM
Here is the two lights. You can obviously tell there's a difference between the two
vcc14 is offline
post #10 of 13 (permalink) Old 03-13-2015, 10:55 AM
Kingsrule5's Avatar
You need the black on a black bike. The back of the reflector is black chrome not just chrome. Still super bright but looks great during the day.
2014 XC Boss Blue/Gloss Black
Tri-Ovals
Lloydz ATS +4
Lloydz Air Filter
1/4 turn throttle
PBR300x2+Alpine SPS-510
Goody Lowers
Klock Works windscreen
2006 Suzuki GSXR 600
Kingsrule5 is offline
