Need help with new wheel orientation - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 03-12-2015, 11:03 PM Thread Starter
MrXC2014's Avatar
Default Need help with new wheel orientation
Ok guys I have a problem, I just picked up my new Victory billet 21" wheel & tire and my local Victory dealer doesn't have wheel changing equipment. I took it to another bike shop and they where hesitate to do the work because it doesn't have any markings on it for orientation no where on that wheel. So if anyone out their, that has the Victory billet wheel or knows how to determine the correct orientation please help me out. See pic's and tell me which side is left or rt as the wheel would be on the bike. I had them install the tire and I hope it's right you can just barley see the arrow on the tirein the last pic. see pic's.
2014 Victory CC, Two-Tone, VM1-HPT-DR, PC5, ATS+4, Llyodz HI-FLOW A/F, 1/4 Turn Throttle Ring, Tuned by Kyle Crandall of KMC PowerSports, Flashed ECM, 121hp 113tq
Suede Supersteel & Black, Madison, AL
MrXC2014 is offline
post #2 of 11 (permalink) Old 03-12-2015, 11:08 PM
Looking in my own service manual (2013) regarding billet front wheel assembly, the side with the bolts is located to the left side of the bike (as you are sitting on it) .. So, yes, the direction of tire travel arrows, seem correct..
Sure is one pretty wheel
Mark-B is offline
post #3 of 11 (permalink) Old 03-13-2015, 12:01 AM Thread Starter
MrXC2014's Avatar
Thanks Mark
The shop I went to wasn't a Victory shop, so they had no info on how to determine the orientation of the rim it self! So to be clear, in the third pic that is the left side when orientated to the bike?
MrXC2014 is offline
post #4 of 11 (permalink) Old 03-13-2015, 06:34 AM
ByteN2it's Avatar
Looks like the dot on the tire is about 90 degrees off from where it's supposed to be lined up with the valve stem-must have been a rookie that mounted the tire?
ByteN2it is offline
post #5 of 11 (permalink) Old 03-13-2015, 06:42 AM Thread Starter
MrXC2014's Avatar
How important is that, to have the dot line up with the valve stem? I'm not trying to be funny, I'm asking cause I don't know and if it's for a safety reason our for alignment purpose I'll take it back and have them correct it.
Thanks
MrXC2014 is offline
post #6 of 11 (permalink) Old 03-13-2015, 07:29 AM
ByteN2it's Avatar
It's a balance thing-probably not a big deal. It just shows a lack of attention to detail on the tire tech's part.
ByteN2it is offline
post #7 of 11 (permalink) Old 03-13-2015, 07:49 AM Thread Starter
MrXC2014's Avatar
Okay very informative I learned something today, Thanks
MrXC2014 is offline
post #8 of 11 (permalink) Old 03-13-2015, 09:59 AM
Originally Posted by MrXC2014 View Post
Thanks Mark
It looks like I have that right.. Again this is from my 2013 Service Manual - See Diagram Below
Mark-B is offline
post #9 of 11 (permalink) Old 03-13-2015, 11:16 AM
Some tire have dots some tires don't.
The dot is a starting point to put by valve stem. Then you spin balance tire to find heavy spot. Now you break the bead on the tire and move the dot to where the heavy spot is.
Wheels don't have a direction to them like a tire does. BUT once you do run it always keep the right side on the right cause that's the way the wheel bearing have seated in
post #10 of 11 (permalink) Old 03-13-2015, 12:57 PM Thread Starter
MrXC2014's Avatar
Thanks again I'm confident now.
MrXC2014 is offline
