Volume down not working since Power Commander install? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-15-2015, 09:04 AM Thread Starter
Default Volume down not working since Power Commander install?
Well, had a Power Commander installed, the bike dyno tuned, and the clutch cable lubed up, but now my radio volume down button no longer works. The other 5 radio control buttons work fine, just not the volume down button.
Took apart the small radio button control console and everything looked fine so I'm guessing the problem is elsewhere. I thought it might be the wiring itself, but there are only 2 wires going into that unit so now I'm not so sure.
Could it be fuse related somehow?
Anyone have any ideas? Thanks!!
2013 Suede Nuclear Sunset Cross Country
Vicbaggers Tarzanz handlebars
Thrush modded exhaust
Saddlebag rails
Avon grips and Avon shifter pegs
Kuryakyn Liberator highway pegs with stirrups
and much more
See this post for more details.
Wyckedjester is offline
post #2 of 6 (permalink) Old 03-18-2015, 08:02 AM Thread Starter
In case anyone is interested, I haven't verified it yet, but I suspect this has nothing to do with the Power Commander. I had the PCV installed on a day that was drizzling and rainy all day and I rode it around all day in that weather. Thinking back about it, I think that control unit got water logged and that's probably what caused this issue. I came across lots of comments about issues with the radio control units and cruise control units getting water logged and that seems are more likely culprit.
I'll let everyone know what I find out for sure when I've had a chance to fix it.
Saddlebag rails
and much more
post #3 of 6 (permalink) Old 03-18-2015, 08:08 AM
invader's Avatar
Look for this connector behind the fairing:
remove the boot, drain it, jam it full of low temp grease, put boot on and seal w/ liquid electrical tape.
This is probably the cause. When mine was full of water, the bike would come on in ACC all by itself, radio controls wouldn't work, etc.
invader is offline
post #4 of 6 (permalink) Old 03-18-2015, 08:29 AM
^^^... Yeah.. Gonna say, probably dirty or bad connection.. I'd definitely be starting there..
Mark-B is offline
post #5 of 6 (permalink) Old 03-18-2015, 08:37 AM
LILMAGS500's Avatar
Those switches are notorious for crapping out in wet weather . Park it in the sun for a while or whack it on and off for a while with a blow dryer .
LILMAGS500 is offline
post #6 of 6 (permalink) Old 03-26-2015, 05:39 PM Thread Starter
Well, it was definitely the controls console that went out. Replaced that thing (about $130) and the problem is solved. Now the lower volume control works just fine.
Saddlebag rails
and much more
