Help bike wont start - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 03-16-2015, 12:32 PM Thread Starter
dromero83's Avatar
Default Help bike wont start
I have a 2013 cross country with a power commander 5 victory performance air filter and big honkers it turns over and its getting gas. I took the spark plugs out and they are getting spark but it just wont start im lost dont know if the power commander is bad or what
dromero83 is offline
post #2 of 21 (permalink) Old 03-16-2015, 12:43 PM
rhino 2's Avatar
Did this just start to happen?? Or right after you added or changed something?
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #3 of 21 (permalink) Old 03-16-2015, 12:48 PM Thread Starter
dromero83's Avatar
No it just happened
post #4 of 21 (permalink) Old 03-16-2015, 01:04 PM
invader's Avatar
fuel pump failure? (recall) not enough fuel?
Mine did something similar at Mt Rushmore. 5 min later (and ever since) it was ok.
invader is offline
post #5 of 21 (permalink) Old 03-16-2015, 01:25 PM Thread Starter
dromero83's Avatar
It was not affected by the recall. It has 3/4 of a tank of gas. Its getting gas when i pull the plugs they are wet from the gas
post #6 of 21 (permalink) Old 03-16-2015, 03:51 PM
I honestly don't have a clue.
Here are some thoughts if no one has anything that works.
I would probably take a look at the battery connections first. Pull the front chin spoiler and sure they were tight. If they were loose I'd fix that and try it again. Without putting the chin spoiler on at that moment.
If that didn't fix it, I would disconnect the battery and reseat all the PCV connectors just for grins. Hook the battery back up and try it again.
My reasoning is two fold. One is that that the PCV adds a second ecu to get it's nickers in a wad. You have one computer over riding another by design. So by powering everything down you let them both reboot from scratch when you power it back up. If they are having some issue with each other they may resolve it when they both reboot from a complete power down. Second, while you are waiting for all the capacitors in the ecm and PCV to bleed down you will be checking to be sure that all the water tight connectors are properly seated and breaking loose any corrosion that may have formed by removing and reinstalling the connectors in the various sensors, injectors etc.
It could work?? If it won't go you are just out your time. Just be careful to not break any of the connectors getting them apart.
That would suck.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 21 (permalink) Old 03-16-2015, 07:35 PM Thread Starter
dromero83's Avatar
I tried disconnecting the power commander and plugging all the stock connectors to see if the power commander was the problem and it still is doing the same thing. I did notice that my battery dies after a few minutes of cranking. Would a bad battery cause it to not start
post #8 of 21 (permalink) Old 03-16-2015, 09:40 PM
From what I have been reading; the battery is one of the weakest links on the Victory motorcycle.
orbiker is offline
post #9 of 21 (permalink) Old 03-17-2015, 04:56 AM
I sort of had this problem. Put my battery on a trikle charge for a say and it started right up. Like the previous post said, the Vic batteries suck. So I went and got a much better battery before I got stuck somewhere .
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #10 of 21 (permalink) Old 03-17-2015, 11:54 AM
if you have wet plugs your bike might not start. Pick up a couple sets of new ones. Don't pump or twist the throttle to start the EFI will do it for you.
Un hooking battery to reset does nothing
