Leaking Rear Shock? - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 03-21-2015, 09:46 PM Thread Starter
luvmyride's Avatar
Default Leaking Rear Shock?
I was installing my adjustable lowering link and noticed some "residue" clinging on the bottom of the shock/mount.
I have noticed the ride suffering (harsh compression, pogo on the rebound), and thought it was the bad roads. Frost heaves (we have a TON of them) send a jolt up my (and my wife's) spines. I had heard of leaking shocks in the past, and I didn't know how the found out, and confirmed, the shock was leaking.
I have had the bike since Sept. '13 (bought new). Any chance of warranty claim? Of course I will take the lowering link off first to make sure they don't blame it on that. I know that couldn't be the problem since I saw it first during the install.
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #2 of 13 (permalink) Old 03-21-2015, 10:06 PM
My rear shock was replaced under warranty during the first year. It would only hold air for a half day or so.
post #3 of 13 (permalink) Old 03-21-2015, 11:03 PM Thread Starter
luvmyride's Avatar
My shock seems to be holding air like normal. I thought the shock had two systems. One oil for damping and one air for preload. The damping is what I've noticed a problem with.
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
VicBaggers:
+6 degree trees
Bag fillers
Tarzanz +2" bars
post #4 of 13 (permalink) Old 03-21-2015, 11:10 PM
If your dealer is worth his/her salt; they will contact Ma Vic and suggest a warranty claim on it. It definitely looks like it has lost oil. Probably a seal went bad on it. It might even be rebuildable but if were you; I would want a new one. Let them rebuild it or whatever they do with the bad ones.
I still have the email address of the service manager where I bought mine. Maybe you could call the service manager, ask for his email address, and send this picture to them for consideration.
post #5 of 13 (permalink) Old 03-22-2015, 05:08 AM
TNXR's Avatar
My shock started leaking oil during the first year I owned it (about 8 months and 3k miles). It was throwing oil on the back tire! Mine was of course replaced under my 1 year warranty but I also think it is a safety issue. They showed me the new shock and before the dealership put it on and I think it was made in China, go figure.
2011 Cross Roads Sunset Red
TNXR is offline
post #6 of 13 (permalink) Old 03-22-2015, 07:15 AM
Motorbikerx's Avatar
yeah I'd be trying for a warranty claim too.
on a different note I notice how restricted the exhaust pipe is going over the oil filter, must shrink down to around half its diameter.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 13 (permalink) Old 03-22-2015, 11:54 AM
You should clean it off really good and the swing arm mount area. Then ride and inspect.
If the shock is holding air I dough you have a leak. Maybe put 70psi in shock or more that way if it is leaking you would force oil out of it.
If it was leaking oil you would have a spot or two on the floor
post #8 of 13 (permalink) Old 03-22-2015, 07:24 PM Thread Starter
luvmyride's Avatar
Thanks, I will see if I can email them before I go to the trouble of uninstalling the lowering link.
That is just the crossover pipe. It has the majority of flow from the throttle side. The stock pipe has good performance, so no need to change it IMHO.
Aren't the air and oil chambers separate?
I thought it would be noticeable on the floor too. If it is leaking out slowly, or while riding I wouldn't see it. The ride quality is so choppy I can't stand it! Anyone that has had their shock leak, did you just notice the leak or did you notice ride quality change?
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
VicBaggers:
+6 degree trees
Bag fillers
Tarzanz +2" bars
post #9 of 13 (permalink) Old 03-23-2015, 05:56 AM
TNXR's Avatar
I did not notice a ride difference between the leaking shock and the new shock. Mine held air just fine, just leaked shock fluid. It was on the floor under the shock after a ride, looked like motor oil at first.
TNXR is offline
post #10 of 13 (permalink) Old 03-23-2015, 07:58 AM Thread Starter
luvmyride's Avatar
Thanks for the reply. That was sort of what I was expecting. It is hard for me to tell if the ride quality suffering is from the shock or the lowering or the back end. I may raise the rear up (from -2" to -1") and see how much difference it makes in ride comfort. If it's still bad I will look into shock replacement
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
VicBaggers:
+6 degree trees
Bag fillers
Tarzanz +2" bars
