Tips for removing factory shift peg and brake peg - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 03-22-2015, 06:53 PM Thread Starter
Default Tips for removing factory shift peg and brake peg
Is there some trick or tip to remove the stock shift peg and brake peg on a Cross Country? I bought some replacement ones from Kury. The instructions say to just use a slip-joint pliers to twist the old ones off. Tried that but the rubber just rotates and looks like it is ready to rip and the peg itself doesn't start unscrewing. I'd rather not destroy the stock pegs.
Any constructive help appreciated.
Thanks,
Rob
2012 Victory Cross Country - Imperial Blue
2008 Honda CBR1000RR - Winning Red
2003 Honda VTX 1800C - Illusion Blue
BigBlue is offline
post #2 of 8 (permalink) Old 03-22-2015, 07:03 PM
Lostintexas's Avatar
One of mine came off pretty easy but it took vice grips for the other. They use some kind of white thread locker and it is some good stuff. Make sure you are turning them to the left and bite the bullet and damn the torpedo's. A heat gun could help but not sure about that, seems like it wouldn't hurt.
The Kury pegs are very nice, I have the extended ones on both sides and am enjoying them. Oh yea, when you get them off clean out the threads and use some blue lock tight, otherwise you may be having the same fight getting the new ones back on.
Good Luck
I ride with the Force.
Lostintexas is offline
post #3 of 8 (permalink) Old 03-22-2015, 08:36 PM
DirtyDan's Avatar
A good pair of vise grips properly adjusted and you should be good to go.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #4 of 8 (permalink) Old 03-23-2015, 01:42 AM
grh450's Avatar
I recently did mine with a rag wrapped around peg for protection,(maybe use later) and VISE grips. Worked like a charm
1983 Yamaha YZ 490
2011 KTM 350 SX
2015 X1
2015 MAGNUM-TRADED
2013 Cross Country-TRADED
2008 Kingpin-TRADED
2005 Vegas Anniversary-TRADED
Gold Canyon, AZ
grh450 is offline
post #5 of 8 (permalink) Old 03-23-2015, 08:55 AM Thread Starter
I'll try the vise-grip idea today.
Thanks,
Rob
BigBlue is offline
post #6 of 8 (permalink) Old 03-23-2015, 04:40 PM Thread Starter
The vise-grip tip helped. I used two. The rubber of one of the pegs (the brake side was really tight) is slightly messed up, but nothing major.
Rob
BigBlue is offline
post #7 of 8 (permalink) Old 03-23-2015, 04:47 PM
Yup Vice Grips, they used thread locker on those things (mine anyway), so use a steady amount of serious force. Don't whale on it, slowly dial up the torque to bust those things loose.
It's a regular thread so, lefty-loosey ..
Mark-B is offline
post #8 of 8 (permalink) Old 03-23-2015, 04:49 PM
I had to vice-grip mine. Fortunately, I wasn't worried about keeping them
