Heated Grips - chrome mount? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 03-23-2015, 08:55 AM Thread Starter
Default Heated Grips - chrome mount?
I'm going to be getting the Vic Heated Grips. On the site, it says 'Requires Chrome Auxiliary Switch Mount (2877659; sold separately).' However, on my XC, there are two spots at the bottom part of the fairing, on either side of the radio display, that are cut-outs for switches. In fact, the manual lists one of these cut-outs as the control for the heated grips (if equipped). Does anyone know if I need to get the auxiliary switch mount if there's already a cut-out in the fairing? Thanks in advance!
2010 Cross Country
2004 BMW K1200LT (Sold to a close friend)
1998 Kawasaki Vulcan (Sold)
2007 KTM 250 XCF-W
jmsnyder01 is offline
post #2 of 5 (permalink) Old 03-23-2015, 10:12 AM
Not necessary on your bike
2012 XC..Tri ovals..forged bars....vic baggers bag fillers..XC mitered chubby bars..chrome switch housings..LLoyds timing wheel, lowered 2", WD floorboards...the list keeps growing..
olemissalum is offline
post #3 of 5 (permalink) Old 03-23-2015, 10:48 AM
use factory switch in fairing. Test before you put fairing together. Its a 3 way switch.
post #4 of 5 (permalink) Old 03-23-2015, 11:06 AM
Might I suggest Heat-Demons internal grip heaters? With them, you can have any grip you desire and have no exposed wires. They come with a good looking 4 speed bar mounted controller too, in chrome or black.
http://www.heatdemon.com/catalog/mot...torcycle-grips
post #5 of 5 (permalink) Old 03-23-2015, 01:52 PM
soofle616's Avatar
as stated you don't need the bracket. neither did i on my xr because it already had oe driving lights which also require that mount for the switch. you're good to go.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
