Passenger Peg Replacement - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 03-23-2015, 06:03 PM Thread Starter
Runinwithscisrs's Avatar
Default Passenger Peg Replacement
Does anyone know what C ring you need as a replacement for the wire spring that hold on the pivot pin for the passenger pegs. I watched the witch doctors vid and used a screwdriver as a chisel to cut them off. Now what do I use to replace them? Victory says they discontinued the old C rings they used to come with. If I go to the hardware store to get one, who has had luck and what size did you use?
Runinwithscisrs is offline
post #2 of 3 (permalink) Old 03-23-2015, 06:11 PM
dtmmil's Avatar
5/16" snap ring
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 3 (permalink) Old 03-23-2015, 06:20 PM Thread Starter
Thanks Drew
