Power amp location - HID in the way - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 03-25-2015, 07:49 AM Thread Starter
MTVic's Avatar
Default Power amp location - HID in the way
Thinking of adding the Witch Dr amp setup, but my 2012 CCT came with the HID display and it takes up the spot Witch Doctor puts the amp. Anyone come up with an easy alternative for this?
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #2 of 4 (permalink) Old 03-25-2015, 08:37 AM
wspollack's Avatar
I have a '12 XCT, too, and the way I mounted my Stebel horn may provide a solution (assuming you don't have a Stebel or anything else in there).
In my gallery, take a look at this particular pic -- www.billanddot.com/victory-xct/#12 -- and a couple of images after that, as this may provide a solution (although I'm not aware of the space requirements of the amp).
That piece of stock is very thick metal. I think it was intended as a cable-wrapping/connecting piece for garage-door cables.
The Stebel is pretty heavy, so this type of thing may work for your amp. Just a thought...
Cheers,
Bill P.
wspollack is offline
post #3 of 4 (permalink) Old 04-08-2015, 10:15 PM
Tinstar5541's Avatar
Yes, I had to use a series of spacers and washers to keep the WD bracket aligned around the HID unit. If you haven't already fixed it, let me know and I can show you pics of what I did
Tinstar5541 is offline
post #4 of 4 (permalink) Old 04-10-2015, 08:23 AM
Easy CCT's Avatar
I had the same issue. Went with this plate to mount on the back of the audio system. Went to Ace Hardware and bought some fasteners to attach
http://www.ebay.com/itm/161516100479...S:1123&vxp=mtr
2012 Cross Country Tour
Lloyds ATS
Stage 1 Tri Ovals
Grasshopper Backrest
Easy CCT is offline
