12v acessory plug help - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 03-29-2015, 09:48 AM Thread Starter
Amboymike's Avatar
Default 12v acessory plug help
2012 Vic XR
Adding a power port for GPS, anyone know which one of these wires in the headlight bucket are the switched + and -
test light broke
Amboymike is offline
post #2 of 10 (permalink) Old 03-29-2015, 12:18 PM
go buy a test light auto store have them.
Test for your self so you get the right one we might be off buy one wire
post #3 of 10 (permalink) Old 03-29-2015, 04:17 PM
ditech's Avatar
I got a plug from victory. It's always on but only drains power if something is left plugged in. Wired directly to the battery and fused. Mounts to the handlebars
ditech is offline
post #4 of 10 (permalink) Old 03-29-2015, 05:09 PM
Carl92's Avatar
That's what I did
Though the cheaper power port i got apparently wasn't rain resistant, as it collected water between the positive prong in middle and the grounded casing, after a heavy rain, causing a lot of corrosion.
This year I'm gonna get another, more water-tight, and with a usb charging port next to it like one of these
2001 Victory V92C
Carl92 is offline
post #5 of 10 (permalink) Old 03-29-2015, 05:21 PM Thread Starter
Amboymike's Avatar
[/QUOTE]
The bottom 2 black connectors are single female spade
black wire ground / Purple w Black is 12v on with switch
Second from top with blue rubber seal is also on with switch
Black is ground / Yellow w Pink is positive
post #6 of 10 (permalink) Old 12-11-2015, 03:21 PM
scooter's Avatar
Black is ground / Yellow w Pink is positive[/QUOTE]
I only got 5v across the connector w/ the blue rubber seal, is it possibly for heated grips?
And the black/yellow w/pink was dead, even with the key on and the bike running. Do I possibly need to add a fuse to make the circuit live?
scooter is offline
post #7 of 10 (permalink) Old 12-12-2015, 07:00 AM
tap into the 12volt line on the headklight and use a relay.
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #8 of 10 (permalink) Old 12-12-2015, 08:55 AM
And the black/yellow w/pink was dead, even with the key on and the bike running. Do I possibly need to add a fuse to make the circuit live?[/QUOTE]
Check for the fuse under the right cover.
2012 Black Cross Country
Waco, Tx.
Wizard is offline
post #9 of 10 (permalink) Old 12-12-2015, 11:32 AM
you want 12v not 5. Your socket has to be grounded and like I said it needs 12 volts
post #10 of 10 (permalink) Old 12-13-2015, 01:27 PM
scooter's Avatar
OK cool. I did finally get 12v on the 3 pin(Black & Yellow w/Pink) connector with the rubber cap on it, I had to take the connector off to make a good contact with my test light because the connectors were so small. I'm going to use that output for my GPS/phone charger. The 2 pin connector is just a switched 5v. I don't know what that low-voltage output is for, but not anything I'll ever use. I have to give Vic a lot of credit for multiple switched outputs, because I have the running lights already connected, and having another accessory feed in the headlight is super convenient.
Thanks for your help folks!
scooter is offline
