Lloydz cams, how much will the power be? - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 1 Post By Lostintexas
  • 1 Post By Pelz
post #1 of 10 (permalink) Old 03-30-2015, 01:12 PM Thread Starter
Default Lloydz cams, how much will the power be?
So I have read previous posts and seen the dyno charts but in practical terms how much power/torque am I going to feel after cams? I ask because I test rode the Indian and wow that was enough torque to get me in potential trouble. Is the cams on the 106 going to provide that type power increase?
Best
JH
John Indianapolis IN
2012 cross country, Adam bomb mufflers
2007Kingpin (sold)
johnah5 is offline
post #2 of 10 (permalink) Old 03-30-2015, 01:19 PM
Probably.
post #3 of 10 (permalink) Old 03-30-2015, 04:54 PM
Put it this way...with cams, Lloyds air filter, ATS and a proper dyno tune with tri-ovals mine came in at 112/112. With different pipes, i could easily had another 4-6 hp and torque. You will smile every time you twist your wrist.
2011 Black Cross Country...21" X-1 wheel, Cams, PC5, LLoyds Airfilter, ATS, 112hp/112T & dynoed tuned by KMC, hydraulic clutch, Witchdoctor brake clutch pedals, chrome bolt kit, colored caps, Ness grips, JTD hard lowers w/lights, 6.5" speaker upgrade in front w/crossovers and RF amp, MM 691 w/crossover and RF amp in speaker lids, passenger grabs, Cee Baileys windshield w/vent, Winner Cycle graphics pin-striping kit, Sentinel Mirrors, Kurakyan lower fork covers
magman is offline
post #4 of 10 (permalink) Old 03-30-2015, 05:10 PM
Lostintexas's Avatar
The 106 will get you in trouble by itself, cams should add nicely to the mayhem.
The 111 and the 106 are very different in power delivery and kind of hard to compare. Well, on paper anyway. HD's seem to have a lot of grunt when riding them, but riding beside them, not so much, the 106 is stronger.
Have fun
tr17047 likes this.
I ride with the Force.
Lostintexas is offline
post #5 of 10 (permalink) Old 03-30-2015, 06:15 PM
If a stock Indian is enough to get you into trouble, stay away from a cammed 106. From 3000 rpm up the 106 will accelerate , oh, about twice as hard as the indian. And you will want to do it over and over again.
tr17047 likes this.
2010 cross roads
Lloyd's air cleaner
Timing wheel
DR cams
Thrush muffler
PC5 Dynotuned by Lloydz
Pelz is offline
post #6 of 10 (permalink) Old 03-30-2015, 06:26 PM
...I'm counting on it, gonna do the drop-in cams / stage-one / PCV with tune package sometime this year.. Gonna do it all at once.. Gonna just need to hold on for a while is all ...
Mark-B is offline
post #7 of 10 (permalink) Old 03-30-2015, 06:43 PM
half_crazy's Avatar
Don't do it, you'll probably lose your license in a month or be killed outright
2006 Victory Kingpin
half_crazy is offline
post #8 of 10 (permalink) Old 03-30-2015, 06:53 PM
Hemidan's Avatar
2010 CR - D&D pipes unwrapped / Lloydz Performance Cams / Lloyd'z Idle Air Valve / Lloydz Adjustable Timing System / Lloydz Hi-Flow Air Filter / PCV w/AT / Vintage Mustang Seat w/backrest / Lock Ride Passenger Backrest / Powerlet Handlebar Outlet / Lay down License Bracket / Adjustable Drop Bracket
Avon Velvet Air Cushion Gatlin Grips/DERBY COVER & CAM COVER SET/Beacon LED Headlight Black
Phase 7 L.E.D. 4-1/2" Passing Lamps/Sabertooth Taillight Accents
Hemidan is offline
post #9 of 10 (permalink) Old 03-30-2015, 07:22 PM
Haha .. I'm old.. Hell ..even advancing the timing by 4 degrees impressed the crap out of me.. I figure, if I can get just a tad more power and tidy up throttle response, I'm gonna have me the scoot I want..
Having said that.. I have issues with moderation.. So.. Never can tell where these things will lead
Mark-B is offline
post #10 of 10 (permalink) Old 03-30-2015, 08:39 PM
Bad-Bolt's Avatar
Figure DR cams, timing wheel, air filter and exhaust average 110/110. Depending on tune and exhaust 117 is in the upper end on XC. Visions have a better intake set up and 120ish is solid expectations.
File Type: jpg IMG_20150310_111216317_1427765712067.jpg (18.7 KB, 26 views)
Bad-Bolt is offline
