Issue with 6th gear? - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 07-16-2012, 01:53 PM Thread Starter
ALStensby's Avatar
Default Issue with 6th gear?
I wanted to see if anyone else has had this issue. I can't get it to replicate and it seems to be very sporadic in nature so bringing it in to the dealer won't do me any good.
I have a 2011 XR with just under 6000 miles. Purchased it last year new, never had this occur. All fluid levels are fine, oil changed at 5,000, etc.
What happens is I'll shift in to sixth gear and get a bit of a clunk a couple of seconds after followed by a second one about another five or six seconds later. Each time it's occurred (five instances or so in all), I just shifted in to fifth and then back up. No issue from there.
The first time it occurred, it was a nice evening...roughly 75F, had been running maybe 5-10 minutes and was going up hill. Was at a decent clip so shifted up and it happened. But two other times, I'd been riding at least two hours in 90F+ weather and on a level road. So, conditions don't seem to be the trigger.
Any thoughts? Anyone else?
Adam
2011 Victory Cross Roads - His
2014 Indian Chief 'Springfield' - Hers
2013 Honda CB500F
ALStensby is offline
post #2 of 21 (permalink) Old 07-16-2012, 02:06 PM
RedRocker's Avatar
Post
No issue when shifting into 6th gear with my 2011 XC, Adam.
Hopefully, KevinX will read and chime in with his thoughts.
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #3 of 21 (permalink) Old 07-16-2012, 02:30 PM Thread Starter
ALStensby's Avatar
Just an FYI, it's not when shifting in to sixth gear that's the issue. It's once I'm "in" sixth gear it occurs.
Adam
2013 Honda CB500F
post #4 of 21 (permalink) Old 07-16-2012, 02:34 PM
CrossRoads's Avatar
Never had that happen on my '11 XR. Is it just an audible clunk, or are there other symptoms as well?
CrossRoads is offline
post #5 of 21 (permalink) Old 07-16-2012, 02:49 PM
Rajder's Avatar
I sporatically have similar issues with 6th gear as well. It only happens very rarely so I would never be able to reproduce it at a dealership. But every so often I'll shift into 6th and I'll get kind of jerking motion and clunking noise that seems like the bike is jumping between 5th and 6th gears. To stop it I usually just pull in on the clutch and pull up on the gear shift like I am trying to shift into a higher gear. That always stops it from happening for me.
I have a theory that maybe the dogs on 6th gear are made in such a way that if you don't get 100% full engagement then you can get some popping in and out of gear or some weird noises associated with 6th gear. Obviously I can't prove that but that is what it seems like is happening to me.
I have 10,000 miles on the bike and it has happened to me less than 10 times. And it seems like it happened more often in the first 6000 miles because I can't remember the last time it happened. I know it's something that I would never be able to take to a service department and replicate so I haven't even inquired about getting it fixed. And it doesn't happen often enough for me to really care all that much about it. But it would be interesting to know if Kevinx knew anything about it.
2011 Cross Country
-Cee Baileys Windshield & Lowers. Victory Lower Bag Rails, Driver And Passenger Backrests.
-RPW Exhaust, Lloydz Air Filter, VM1 Cams, ATS (Timing Wheel), 1/4 turn throttle & IAV. PCV with Custom Tune by Coweta Customs.
105.2 HP & 127 Ft-Lbs on a Dynostar (Eddy Current) Dyno.
Rajder is offline
post #6 of 21 (permalink) Old 07-16-2012, 02:57 PM
To be a Buttinski here, I'll toss these out to ya....
+ Are you shifting at 3500 rpm +?
+ Do you preload the shifter?
+ Is the clutch cable adjustment correct?
Anything else is more than I know and hopefully KevinX is eavesdropping and will salve our inquiring minds.
post #7 of 21 (permalink) Old 07-16-2012, 02:58 PM Thread Starter
ALStensby's Avatar
Read Rajder's reply...that's pretty much exactly the feeling. One of the times, I do recall not feeling like I really got a full engagement in to sixth...so wondering that could be it.
Adam
2013 Honda CB500F
post #8 of 21 (permalink) Old 07-16-2012, 03:09 PM
CrossRoads's Avatar
As RICZ mentioned, I would check the clutch cable to make sure it's adjusted correctly before pursuing this any further.
post #9 of 21 (permalink) Old 07-16-2012, 03:24 PM
irv
irv's Avatar
i have had it happen a few times taking off in first gear
too. like something was engaging and then did.
mph faster].
irv is offline
post #10 of 21 (permalink) Old 07-16-2012, 06:46 PM
ammo_umb's Avatar
Is it happening with cruise on, with cruise off or both? If it's just with cruise on it's probably struggling because you're going up hill. If it's with cruise off it may be gear lash.
2011 and newer transmisions were redesigned and have considerably less gear lash then older transmissions but with low RPM combined with low load you may be feeling the little bit of lash that's left.
Retired USAF, IYAAYAS!
ammo_umb is offline
