rear light problem - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 07-16-2012, 03:31 PM Thread Starter
irv
irv's Avatar
Default rear light problem
yesterday we rode with another couple and after our first stop
he told me the r rear turn signal light would blink once in a while.
i asked if he was talking about my brake light, because i would
kick the cruise off every once in a while w/the brake lever. he
said no, it was the r rear turn signal. i dont know if the front
was coming on too. cant see either one. anyone else have this
happen and any ideas?thanks !--irv
mph faster].
irv is offline
post #2 of 9 (permalink) Old 07-17-2012, 08:04 AM
handyhoward's Avatar
sumpton loooose... seriously, it's a loose connection or a loose bulb or a short in the wire. Start with making sure the bulb is inserted firmly in the socket.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #3 of 9 (permalink) Old 07-17-2012, 08:47 AM Thread Starter
irv
irv's Avatar
never thought about it before. are the rear signals leds
or bulbs?
just looked at the fiche .all rear lamps are sealed units.
mph faster].
irv is offline
post #4 of 9 (permalink) Old 07-17-2012, 09:37 AM
or bulbs?
When I said to check the bulbs, I meant the LED assembly. It is a plug and play arrangement... and the plug must be tight to work properly.
Handy
post #5 of 9 (permalink) Old 07-17-2012, 09:46 AM
ridinman's Avatar
Was it blinking randomly when it was not supposed to or was it functioning sporadically when it was supposed to be flashing?
All lights on the cross bikes are LED, except the headlights.
Ride Safe, Ride Often
Life's to short to be GRUMPY
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #6 of 9 (permalink) Old 07-17-2012, 10:28 AM Thread Starter
irv
irv's Avatar
randomly w/o using the signals
mph faster].
irv is offline
post #7 of 9 (permalink) Old 07-17-2012, 11:01 AM
ridinman's Avatar
That's an odd one.
It's not likely that you would have 2 wires worn to the point of allowing voltage to get to the bulb circuit. May be a problem in the turn signal controller.
I'd try to recreate it. Make sure it wasn't sunlight reflecting off the chrome onto that bright red bike.
Bill
2014 XCT
Lenexa, KS
ridinman is offline
post #8 of 9 (permalink) Old 07-17-2012, 12:56 PM Thread Starter
irv
irv's Avatar
never know.this is the same guy who told me my headlamp
wasnt on before.course its not super bright.
do any of you guys run with your brights on instead of low beams?
i have never been out after dark to find out how the lights are
and we have about 4400 miles on it.
mph faster].
irv is offline
post #9 of 9 (permalink) Old 07-17-2012, 01:15 PM
ridinman's Avatar
I used to run with the high beams on, until I put in the HID bulbs. No need now. I've been told the high beam is too much even in the daylight.
If you have the stock bulbs, turn your high beam on. Try to be as visible to the cage drivers as possible.
Bill
2014 XCT
Lenexa, KS
ridinman is offline
