rear brake rotor has play? - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 04-01-2015, 10:56 AM Thread Starter
45caldan's Avatar
Default rear brake rotor has play?
I was checking out brake pads and belt tension, etc. the other day and I noticed the rear rotor has some "play" in it. where the part of the rotor that the pads come in contact can be wiggled a little from the part that it is riveted to, that bolts to the wheel.
Is this normal????
Rivets coming loose??
Bad rotor??
thanks!
2010 Cross Roads
Vic HP air filter
Stage 1
D&D slash cut mufflers
Lloyd's Adjustable Timing Wheel @ 4
Kuryakyn Engine Guard Driving lights
Sabertooth auxiliary tail lights
7jurock custom WS with vent
Cee Bailey lowers
Ness Tear Drop mirrors
45caldan is offline
post #2 of 11 (permalink) Old 04-01-2015, 11:13 AM
how much wiggle. The thickness of a peace a paper or more
post #3 of 11 (permalink) Old 04-01-2015, 11:14 AM Thread Starter
45caldan's Avatar
I guess a millimeter or 2.
The front ones have zero wiggle...
2010 Cross Roads
Vic HP air filter
Stage 1
Cee Bailey lowers
45caldan is offline
post #4 of 11 (permalink) Old 04-01-2015, 11:17 AM
maybe you could do this to "all" the buttons
https://www.youtube.com/watch?v=nqcHw_t3QlU
post #5 of 11 (permalink) Old 04-01-2015, 11:44 AM
Pretty sure its a floating rotor, so that is normal.
vcc14 is offline
post #6 of 11 (permalink) Old 04-01-2015, 11:58 AM Thread Starter
45caldan's Avatar
Ok that may be good news but the CALIPER also has a little "wiggle" also with all bolts that I can see tight....
Again normal??
thanks guys!
2010 Cross Roads
Vic HP air filter
Stage 1
Cee Bailey lowers
45caldan is offline
post #7 of 11 (permalink) Old 04-01-2015, 12:30 PM
Floating rotors move a little, as do the calipers so maximum pad/rotor contact is achieved. If your bolts are tight and everything is aligned properly, you're good to go.
broggyr is online now
post #8 of 11 (permalink) Old 04-01-2015, 12:33 PM Thread Starter
45caldan's Avatar
Thanks again guys!
Hate to pay a Tech. to tell me I'm GTG!
2010 Cross Roads
Vic HP air filter
Stage 1
Cee Bailey lowers
45caldan is offline
post #9 of 11 (permalink) Old 04-04-2015, 08:41 AM
Jamming's Avatar
This is 100% correct...and might I add...remember that the brakes take the energy of your momentum and convert it to heat. That is why there's a little play....heat causes expansion....physics is your friend, and yes I'm a physics geek
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
post #10 of 11 (permalink) Old 04-04-2015, 07:39 PM
rychemind's Avatar
My rotor on my jackpot got loose like it was coming apart made a lot of noise also you are better to just replace it. Be safe.
2006 Jackpot
2012 XCT, Pearl White, Ness Big Honkers, Lioydz IAC,
PCV, Lloydz Air Fil
ter
rychemind is offline
