Motor Making Bad noises - Victory Forums - Victory Motorcycle Forum
post #1 of 39 (permalink) Old 06-14-2015, 11:29 AM Thread Starter
Blubyu's Avatar
Default Motor Making Bad noises
Took a nice ride down to Ocean City, MD yesterday with my buddy who rides a Harley Road Glide. Headed back, we maintained a pretty good pace with him leading the way. Then I hear a strange "metallic rapping/tapping" sound. Seemed less when I'm under load. When I let off the throttle, it's accompanied by a raspy rattling sound. Pulled over to do an inspection. Tapping seems to be coming from lower rear cylinder, rasping rattling (when I let off of the throttle) seems to be coming from top of rear cylinder head. No smoking and seems to be no degradation of power, although I didn't really get on it after I heard the noise. I limped in home last night and put it in the garage. To make matters worse.. I have to hear all my Harley Buddies talk about how they I broke down trying to keep up with the Harleys! SMH. I'll try to do a sound clip later today.
Blubyu is offline
post #2 of 39 (permalink) Old 06-14-2015, 11:31 AM
toejam's Avatar
Possible cam chain tensioner?
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #3 of 39 (permalink) Old 06-14-2015, 11:46 AM Thread Starter
Blubyu's Avatar
Default Motor Making Bad Noises
I'll have to check the symptoms of a tension failure
Blubyu is offline
post #4 of 39 (permalink) Old 06-14-2015, 07:16 PM Thread Starter
Blubyu's Avatar
Default Vido Clip of tapping of motor
Did a quick video to try to get the sound of the tapping of the motor. Kind of hard to get the true sound.
https://www.youtube.com/watch?v=qank...e_gdata_player
Blubyu is offline
post #5 of 39 (permalink) Old 06-14-2015, 07:50 PM
Turned out to be a private video. You are asking for help with a bike we know little about cuz you won't post a signature with a description of it and the mods you've done. Help us to help you, will ya huh?
post #6 of 39 (permalink) Old 06-14-2015, 09:46 PM Thread Starter
Blubyu's Avatar
Default My set up
Didn't realize it was a private video..I've only loaded two videos prior..still getting the hang of it. Wil try to resend another. My set up.
Lloydz Freedom performance high compression pistons (10.8:1)
Lloydz HOH-VM1-DR Performance Street Cam
Lloyds ATS (+2)
Lloyds performance Air Filter
Bassani Slip ons
Blubyu is offline
post #7 of 39 (permalink) Old 06-14-2015, 10:57 PM
And the year is.....? If its a 2014, we may know what the problem is. You tell us and we'll tell you, since you are playing hide and seek with the ID of your bike. Yes, I can be a cranky old fart. Rank has its privileges, being the most senior guy here.
post #8 of 39 (permalink) Old 06-14-2015, 11:27 PM Thread Starter
Blubyu's Avatar
Default Tapping in motor
It's a 2011 Cory Ness Cross Country... #99.
Not trying to be elusive at all...Gotta help you to help me!!
Blubyu is offline
post #9 of 39 (permalink) Old 06-14-2015, 11:35 PM
Simply make the video public. Then we will be able to view it.
How many miles on the motor? Any motor work done like a 116 kit or cams?
There has been some talk lately about not letting the motor warm up before heading out and opening the throttle.
Could be piston slap. A pain to fix but not the end of the world. Could also be cam chain tensioner is slack as mentioned or even a referred noise coming from the primary from the compensator.
post #10 of 39 (permalink) Old 06-14-2015, 11:44 PM
Could be a drained tappet or tappets. How many miles on the oil and what brand/weight?
