bike wont start ! - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-17-2015, 06:20 PM Thread Starter
Default bike wont start !
Hi shut bike off after work tonight and went to start it up and nothing keys on kill switch is off in neutral push start button nothing! Fuel pumps runs all lights come on any ideal that I'm missing thanks.Rick
woodchuk is offline
post #2 of 13 (permalink) Old 06-17-2015, 07:13 PM
Try pulling in the clutch? Shift into first then back into neutral? Toggle the kill switch back and forth?
post #3 of 13 (permalink) Old 06-17-2015, 08:20 PM Thread Starter
I did toggle the kill switch tried putting in gear and back also .
woodchuk is offline
post #4 of 13 (permalink) Old 06-17-2015, 08:39 PM
Is there any clicking when you hit the starter button? Maybe the battery is weak? Battery connections loose?
post #5 of 13 (permalink) Old 06-18-2015, 03:45 AM Thread Starter
nope no clicking noise nothing thought maybe the switch went bad?
woodchuk is offline
post #6 of 13 (permalink) Old 06-18-2015, 04:42 AM
Did you try pulling in the clutch while pushing the starter button even though you were in neutral and shouldn't need to have the clutch in?
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 13 (permalink) Old 06-18-2015, 04:50 AM
beast30's Avatar
Not sure what year/model we're talking about here. There should be a main circuit breaker right off the positive lead of the battery. Replacements can be had at Napa or equivalent auto parts store for usually under $10. You can Google or use the search feature on this forum titled " main circuit breaker" and probably find heaps of info on replacement part numbers. Hope its an easy fix.
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #8 of 13 (permalink) Old 06-18-2015, 11:27 AM
what year and model bike do you have
post #9 of 13 (permalink) Old 06-18-2015, 07:03 PM
ammo_umb's Avatar
Per intro post the OP has a 2011 XC
Retired USAF, IYAAYAS!
ammo_umb is offline
post #10 of 13 (permalink) Old 06-18-2015, 08:19 PM
Pauljp's Avatar
The starter system is fairly easy to troubleshoot.
Start at the battery + and using a test light or meter work your way back.
We know the 40 amp breaker is good since his lights and dash work.
Go through the 10 amp fuse, through the ignition switch, run/stop switch, start switch and to one side of your starter relay.
If you have 12 volts getting there, then check the clutch switch that should provide a ground to the other side of the starter relay coil.
With a good 12 volts on one side and a good ground on the other, that relay should energize, providing a massive 12 volts directly from the battery to the starter.
If it doesn't then replace the starter relay.
You could also test the starter, put your bike in neutral and leave the key off, you don't need the bike on to test this.
Short out the two large cables across the starter relay, this will put 12 volts directly to the starter and it should turn the engine.
Of course it won't start because your bike is off, but it should still turn the engine. If it doesn't then you may have a bad starter.
Hope this diagram helps.
Paul
Gatineau Quebec, Canada
Pauljp is offline
