Installing Fuel/Air upgrades and NEED Advice - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-21-2015, 03:06 PM Thread Starter
AllenT's Avatar
Default Installing Fuel/Air upgrades and NEED Advice
I have a 2012 Crossroads with 17,000 miles.
I bought it used at 15,000 miles and the factory pipes had been gutted but no other mods. I have removed those pipes and put on RCX slip ons. I have disconnected the O2s.
I have ordered a Lloydz adjustable timing wheel and air filter and a PC5 which i will put on. Not doing the PC auto tune. The plan is to then ride it over (about 20 miles) to have it dyno'd.
Should I go ahead and set the timing wheel to a 4 degree advance? Will the bike function enough to get it to the dyno? (this is my biggest concern). Haven't seen this addressed anywhere. THANK YOU for helping me learn more!
AllenT is offline
post #2 of 12 (permalink) Old 06-21-2015, 04:04 PM
There's only one way to find that out. I can't say, having never been where you're at.
post #3 of 12 (permalink) Old 06-21-2015, 04:08 PM
lunaticrider's Avatar
I would try 4 to start with and you should be fine to ride it the 20 miles to the dyno shop. If you get detonation (ping) then just take it easy and mention it to the dyno operator...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #4 of 12 (permalink) Old 06-21-2015, 06:39 PM Thread Starter
AllenT's Avatar
I appreciate it Lunaticrider
AllenT is offline
post #5 of 12 (permalink) Old 06-22-2015, 12:53 PM Thread Starter
AllenT's Avatar
anybody else have info, please?
AllenT is offline
post #6 of 12 (permalink) Old 06-22-2015, 01:18 PM
The air filter is going to lean it out a lot more then the wheel. What map is in the PCV? If you need a map download one from Dynojet. They are way rich, you will be fine riding 20 miles.
2010 cross roads
Lloyd's air cleaner
Timing wheel
DR cams
Thrush muffler
PC5 Dynotuned by Lloydz
Pelz is offline
post #7 of 12 (permalink) Old 06-24-2015, 11:48 AM
Should be fine with O2 disconnected it will be rich.
Just don't run over 100 mph getting there.
Nuggetcharger is offline
post #8 of 12 (permalink) Old 06-24-2015, 12:00 PM Thread Starter
AllenT's Avatar
LOL! Thanks Nuggetcharger...in Houston traffic that's not EVEN possible
AllenT is offline
post #9 of 12 (permalink) Old 06-24-2015, 12:41 PM
Default premium recommended
in lloydz instructions you see premium fuel is recommended. as you know the timing wheel effects timing from start to finish. the power commander will not adjust timing under 2,000 rpm if i remember correctly. i run +6 on my hammer in Pa with 93 octane always. hotter temps that you prolly see will cause pinging sooner as will riding double + xtra cargo lbs. properly done dyno tuning using the power commander is best. i opted for the adjustable dobeck gen 4 AFR+ with AFR gauge, good fueling control but no timing adjustment that can enhance power + economy, no dyno tune. my hammie already has more balls than I!!!!
rodhotter is offline
post #10 of 12 (permalink) Old 06-24-2015, 12:52 PM
20 miles you will be fine just watch for ping like already stated. Disconnecting O2 for just pipes is good rule of thumb if you were only doing pipes. Changing air in needs more fuel. The O2 disconnect will give you a bit more fuel but not what is needed...and even making it a bit richer it is still lean by fueling standards. A good tuner will run your before numbers and adjust the wheel accordingly. The timing wheel adjusts timing through the full rpm range whereas the pc5 software can do above 2500 rpm
lykoi626 is offline
