Weird noise when cold - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 06-23-2015, 06:11 PM Thread Starter
Nodnarb's Avatar
Default Weird noise when cold
My bike is getting ridden much less these days I'm sad to say. She's got around 35k miles on her and I haven't done anything except change the oil and some fork seals. But recently I've noticed when I start it up I get a ticking/clicking noise that seems to come from the front cylinder and goes away quickly once the motor is warm.
So, does this sound familiar to anyone here?
10' XC Skulls
stock...for now
10' Hammer S (traded in for the Skulls)
Suede B&W
RPW Big Slash
Lloyds AirBox
Lloyds VFC3
95 HP
109 TQ
Nodnarb is offline
post #2 of 17 (permalink) Old 06-23-2015, 06:14 PM
Probably a lifter
vcc14 is offline
post #3 of 17 (permalink) Old 06-23-2015, 07:04 PM
+1 on the hydraulic valve lifters. They may drain when the bike sits for a long time. Good reason not to rev it while it warms. What oil and weight?
post #4 of 17 (permalink) Old 06-24-2015, 04:47 PM
johnnyplano's Avatar
Yep, oil has to make its way up to the lifters. It may take a second or two. Just one of the reasons to always let the bike warm for at least a few seconds...
2013 Cross Roads Classic
Tri-Oval Stage 1
Lloydz ATS
OEM Tachometer, Windshield Lowers, Driver & Passenger Backrests
Ultimate Midrider Seat
Kuryakyn Sabertooth Tail Lights
Ricz Lay Down License Plate Bracket
28,000 (s)miles and counting...
johnnyplano is offline
post #5 of 17 (permalink) Old 06-24-2015, 07:50 PM
Also a good reason to crank your bike and let it run for a while once a week even if you are not riding it.
Oil can run off cyl walls too and humidity can and does cause cyl walls to rust and even the rings to seize to the walls. Now this usually happens with very long periods of time sitting, but none the less, crank that thing up once a week.
Sportsmanphil is offline
post #6 of 17 (permalink) Old 06-24-2015, 08:37 PM
ONLY IF YOU INTEND TO TAKE IT OUT AND RIDE IT FOR AT LEAST A HALF HOUR. Sorry, I had to shout over this incorrect bit of advice. If not riding, put stabilizer in the fuel and an automatic trickle charger on the battery. Running it for a few minutes does so many bad things I am not even going to start listing them.
post #7 of 17 (permalink) Old 06-25-2015, 07:13 AM
BP6666VR's Avatar
Fuel Stabelizer ? Never did that ... Should I ?
I work 4 on 4 off so 6 montjs a year parked and trickled ....
Agreed, starting an engine weekly is BAD if not used .
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 17 (permalink) Old 06-25-2015, 10:47 AM
Yup! Fuel has about a 30 day shelf life and then bad stuff starts settling out to gum up the works. Stabilizers aid in preventing that. Very cheap insurance. Do they sell it where you are?
post #9 of 17 (permalink) Old 06-25-2015, 11:11 AM
LILMAGS500's Avatar
Could be a cam chain tensioner also ... Very common .
LILMAGS500 is offline
post #10 of 17 (permalink) Old 06-25-2015, 11:16 AM
DillPickle311's Avatar
Shoot! That's the time to sell it 'click'. I'll give you 5000 for it since it needs some work on it(as in riding it).
DillPickle311 is offline
