ABS light staying on - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-23-2015, 09:22 PM Thread Starter
Stilhav9's Avatar
Default ABS light staying on
Well I got back Sat from my trip to Panama City Fla., rode over 1680 miles . Zero issues , fantastic ride on my XCT . Last night I rode 10 miles to the hardware store again no issues . On way back from hardware store my ABS light stayed on all the way home . Today after work decided to give her a bath . Afterwards I fired her up and let her run for a few minutes . The ABS light stayed on the entire time . Never had a bike with ABS before , so is this something that I can fix ? Will it go away ? Or do I have to take it to a dealer ?
Any advice would be greatly appreciated.
2012 Cross Country Tour
Sunset Red
Stilhav9 is offline
post #2 of 6 (permalink) Old 06-23-2015, 11:29 PM
mr.b's Avatar
I can't solve the 10 mile issue, but when you start the bike it has to hit 8 mph or so to go off. Sitting there idling, the light will stay on forever.
mr.b is offline
post #3 of 6 (permalink) Old 06-24-2015, 02:10 AM
The same thing happened to me on a long trip. The ABS light would go on at random times and would stay on until I turned the bike completely off and then on again. This problem has been reported in this forum previously and the most commonly recommended way to fix it is to adjust the gap between the abs wheel speed sensor and the ribbed wheel ring to make this gap smaller. I have not yet done this because my problem mysteriously went away shortly after my return from a long trip.
If you repair this problem, please post back in this thread with your solution. Thanks.
G'day,
Vinish
Vinish is offline
post #4 of 6 (permalink) Old 06-24-2015, 05:21 AM
depot picker's Avatar
Making sure the sensor and the tone ring are clean is important too. I had to adjust my gap to wide to the maximum, 1.25 mm, to gat it reliable.
depot picker is offline
post #5 of 6 (permalink) Old 06-24-2015, 02:33 PM Thread Starter
Stilhav9's Avatar
Thanks for the input . I plan on taking a little ride tonight and will obviously check on the ABS light . If it stays on again I will be looking into adjusting the gap . I will keep all posted .
Thanks again for the assistance .
Sunset Red
Stilhav9 is offline
post #6 of 6 (permalink) Old 06-25-2015, 11:23 AM Thread Starter
Stilhav9's Avatar
Well I took my little ride last night. Went to the same local hardware store and after take off the ABS light went off . Also on my way home the light went out again so must have been a glitch or perhaps some dirt. Either way I am happy that all is well .
Sunset Red
Stilhav9 is offline
