Where to mount Speaker's Tweeter (6 1/2 components) - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 06-25-2015, 09:22 AM Thread Starter
FuzzyKing's Avatar
Default Where to mount Speaker's Tweeter (6 1/2 components)
I know alot of people on here have either 5 1/4 or 6 1/2 component speakers in their fairing, I am looking at some ideas/pictures of how you mounted the tweeter. I don't want to cut a hole in the grille cover, just for the reason of the speakers I have are not water resistant, so I want to have them mounted inside to help a little from getting rained on. I will be putting in Kicker KSS65's.
2011 XC White Silver
L&R Trunk
Tri-Oval Stage 1 Exhaust
I-Pod Conversion
Shorty Ant.
Madstad WS Bracket
Madstad 9" Solid Dark Gray
Victory Heel Shifter
Debadged Tank
Victory LED headlight
Lloydz Timing Gear
Lloydz 1/4 Turn Throttle
LED Speaker Lights
Kicker 6 1/2 Component Speakers
LED Floorboard Turn Signals
Soundstream PN4.1000D
Kuryakyn Skinni Mini (Removed)
Victory HID conversion (High/Lo) (Removed)
2004 Kingpin
2005 Vulcan 900 Classic
Duluth, Minnesota
FuzzyKing is offline
post #2 of 19 (permalink) Old 06-26-2015, 11:21 PM
jbb6811's Avatar
wow that's a tough one seeing youre not wanting to modify the grilles. youre gonna have to make a bracket and probly use the screws to inner and front fairing as mounts.
if I was you id mount them in the grilles and just use quick disconnects for the tweeter so when washing the bike and what not you could easily remove them.
either way good luck
2011 8 Ball Vegas(gone but not forgotten)
2014 XC White
jbb6811 is offline
post #3 of 19 (permalink) Old 06-27-2015, 09:30 AM Thread Starter
FuzzyKing's Avatar
That is a good idea about the quick disconnects, and I was thinking of making some sort of cover, ie a cut plastic bag, that I could put over the grill if I am at work or somewhere and the bike will get rained on. I know that I have seen some pictures on one of the million threads about amps/speakers of people making their own brackets, but I can't find them anymore.
L&R Trunk
I-Pod Conversion
Shorty Ant.
Madstad WS Bracket
Debadged Tank
Lloydz Timing Gear
LED Speaker Lights
2004 Kingpin
Duluth, Minnesota
post #4 of 19 (permalink) Old 06-29-2015, 01:18 PM
jbb6811's Avatar
Found this today. Thought it might help.
2014 XC White
jbb6811 is offline
post #5 of 19 (permalink) Old 06-29-2015, 02:54 PM Thread Starter
FuzzyKing's Avatar
Thanks JBB6811. I was kind of think that.
L&R Trunk
I-Pod Conversion
Shorty Ant.
Madstad WS Bracket
Debadged Tank
Lloydz Timing Gear
LED Speaker Lights
2004 Kingpin
Duluth, Minnesota
post #6 of 19 (permalink) Old 06-29-2015, 06:32 PM
jbb6811's Avatar
No problem bro. Good luck hope it turns out great!
2014 XC White
jbb6811 is offline
post #7 of 19 (permalink) Old 08-17-2015, 05:04 PM Thread Starter
FuzzyKing's Avatar
Well, speakers are mounted, still need to paint the bracket but that might be a winter project. I used the Scosche VW adapters for the Kicker 6 1/2 components. I didn't have to file down some of the adapters because the rubbed against the fairing and made noise going down the highway. Sounds good, but a Soundstream amp and VTwin Audio amp bracket, will be going in over the winter.
L&R Trunk
I-Pod Conversion
Shorty Ant.
Madstad WS Bracket
Debadged Tank
Lloydz Timing Gear
LED Speaker Lights
2004 Kingpin
Duluth, Minnesota
post #8 of 19 (permalink) Old 08-17-2015, 08:20 PM
HowardGNelson's Avatar
my soundstream amp is sitting at my house. i got the PN4.1000D
140 watts RMS x 4 @ 4ohms
ill be putting it in when i get home on the 27th, along with some power acoustic tweeters, and the JTD hard lowers.
hey not trying to thread jack but does anyone know off the top of their head what i can pull 12v for my remote wire from? (what color wire)
2012 XCT Sunset Red - D&D's, Lloydz filter, ATS +4, Clearwater Krista's, Fusion LED kit, Rusty Jones single din, Sony head unit, PCV, BAB Tank Lift, BAB 1/4 Turn, Kenwood 400x4 amp, Soundstream 1000x4 amp, Focal 6.5s, DS18 tweeters, Polk Audio DSi5.25s, Rick Fairless mini apes
RIP my 2010 Victory XC-Skull bike (Totaled 10/21/16)
07 Jackpot Premium - white w/ flames(SOLD)
**Stop saying "how dumb can you be", people seem to be taking it as a challenge**
HowardGNelson is offline
post #9 of 19 (permalink) Old 08-19-2015, 06:22 PM
chunter's Avatar
I tapped into the power wire for the iPod plug. I think it was red, but don't quote me, it's been a while. If you have a volt tester, just touch the node to the pin inside the plug and ground it out. Make sure you at least have the acc turned on!
chunter is offline
post #10 of 19 (permalink) Old 08-24-2015, 06:35 PM
There is a blue wire with a pink tracer that I used it is switched 12 v power
David1807 is offline
