23" or 26" front wheel that is the question? - Victory Forums - Victory Motorcycle Forum
post #1 of 30 (permalink) Old 06-30-2015, 03:42 PM Thread Starter
Cheez's Avatar
Default 23" or 26" front wheel that is the question?
I just ordered the vicbaggers triple trees to start collecting my parts for the front end but am torn between a 23" or 26" wheel. The 26" looks like it cost about $2k more +/- a few dollars but looks sweet. And then I think of the other options I could use that for if I did a 23" wheel instead(hard lowers, speaker lids, etc...). What are the pros and cons for one versus the other? Thoughts?
Cheez is offline
post #2 of 30 (permalink) Old 06-30-2015, 05:54 PM
Not knowing if you have abs. You would need a new ring new fender kickstand and the higher you go the shity your ride will get. Your cornering will change and your exhaust can drag.
You'll become a profiler and not a rider
stick a 2 1/2" board under your tire and see what you think. Put a board under kickstand if you do
post #3 of 30 (permalink) Old 06-30-2015, 06:09 PM Thread Starter
Cheez's Avatar
This will give me the riding stance of the bike for the 23" I'm guessing which I think I'm leaning more towards just bc I can do other things with the cost difference for the bike.
Cheez is offline
post #4 of 30 (permalink) Old 06-30-2015, 08:41 PM
luvmyride's Avatar
I have a 23" and have ridden HARD in the mountains. It handles GREAT! The ride is no different, but the turning radius is bigger. It just takes a little getting used to (slamming the BACK end, is another story).
Check out my Dragon thread/review
https://www.victoryforums.com/showthr...+of+the+dragon
I think if you are wanting to ride/tour on it, go 23". If you want a show bike go 26". The XC stands out so much in a sea of HDs that the ridiculous big wheels aren't necessary. The 23" I have gets a TON of attention (all positive, at least to my face).
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #5 of 30 (permalink) Old 06-30-2015, 09:02 PM
philmonger's Avatar
There is no way a bigger front wheel improves the handleing of the bike. You can profile, but lose real world rideability.
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #6 of 30 (permalink) Old 06-30-2015, 09:13 PM
DirtyDan's Avatar
So not true. How many people do you know with big wheels? None I'll bet. There are guys who ride 1000's of miles with big wheels and guys with stock bike who barely ride. My 23 handles great. Slight learning curve just like anything else. I'm sure you don't like choppers too. Each to their but don't talk to something you gave no personal experience with. I can't wait for my 26. Should have skipped the 23"
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #7 of 30 (permalink) Old 06-30-2015, 09:30 PM Thread Starter
Cheez's Avatar
See that's what I'm worried about. I don't want to wish I had just went 26" from the gate. I know I'll ride the hell out of it no matter what size wheel is on it. But I have also seen a few 26"s that the fairing just doesn't look right. Like it's too far away or sits too high and a lot of the pics of 26" bikes are slammed with an air ride so it's hard to tell what the front end looks like in a riding stance. So I don't want something that looks ridiculous. I have seen a 23" bike in the same color as mine and it was impressive. But I have yet to see a 26" in person that's what makes it difficult bc things don't always look as good in person as they do in pics
Cheez is offline
post #8 of 30 (permalink) Old 06-30-2015, 09:36 PM
philmonger's Avatar
If big front wheels improved handling, all the manufacturers would be competeing for the biggest. Flat roads may be fine. Try Hurricane Mountain Road in NH with a big wheel.
post #9 of 30 (permalink) Old 06-30-2015, 10:04 PM Thread Starter
Cheez's Avatar
I'm not looking for improved handling it's more for just overall look of the bike. I understand handling will be affected but I'm used to it. My other bike I ride has a big back tire and is slammed.
Cheez is offline
post #10 of 30 (permalink) Old 06-30-2015, 10:52 PM
Krisd's Avatar
Yep totally agree
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
