Nitrogen in Tires - Victory Forums - Victory Motorcycle Forum
post #1 of 27 (permalink) Old 07-07-2015, 06:46 PM Thread Starter
ZNess-CC-073's Avatar
Default Nitrogen in Tires
I do this in my trucks religiously since we tend to get major temperature fluctuations. I've yet to see a change of more than 1psi across major weather swings.
Has anyone had their motorcycle tires filled with nitrogen?
Mike
Current Fleet
2013 Cross Country Zach Ness Custom #073
-Lloydz Exhaust, Air Filter, Timing Wheel +4, & 1/4Turn
-DynoJect PowerCommander V c/w AutoTune
2013 Polaris 850XP EFI EPS - Blue Fire
History's Garage
2010 Kawasaki Vulcan 900 LE Custom
ZNess-CC-073 is offline
post #2 of 27 (permalink) Old 07-07-2015, 07:02 PM
541RF's Avatar
It's not the pressure change that the nitrogen helps it is the freezing water in the compressed air that is the problem. Nitrogen is dry air, so it will not freeze at very low temperatures. Aircraft use nitrogen on all large aircraft tires.
541RF is offline
post #3 of 27 (permalink) Old 07-07-2015, 10:05 PM
SuperDog's Avatar
Actually, all aircraft tires are filled with nitrogen BECAUSE of its thermal stability. They don't want an aircraft coming down from high altitude and COLD tempetures (which causes air pressure to drop in tires, don't believe then blow up a balloon in a room that is say 70 degrees and then put it in a freezer for say a half an hour and tell us all what you discover) to land on flat tires.
"Be Water, My Friend" Bruce Lee 1971
2013 CCT Grasshopper Drivers Backrest, PVC Self Made 1/4 turn Throttle Ring, Thrush Self Modded Mufflers, Kuryakyn 4526 Tour-Tech Adjustable Cruise Mount/Tour-Tech Pegs
SuperDog is offline
post #4 of 27 (permalink) Old 07-07-2015, 11:30 PM
No nitrogen in my bike, but I do have it in my car. The first thing I noted is, in hot days, the tire pressure doesn't increase dramatically, like it did prior to installing nitrogen. I'm not enthused about putting nitrogen in my bike's tires because their service life is a fraction of car tires and the contact patch is much smaller, generating less heat.
post #5 of 27 (permalink) Old 07-08-2015, 12:34 AM
Kingsrule5's Avatar
I'm thinking about doing it just for the fact that in AZ we can have a 30-40 degree swing between daytime high and nighttime.
The maintenance guy at the local dealer told me he put nitrogen in his and was able to see about a 2000 mile difference in tire life compared to average on the stock tires. He said it may have been luck but only thing he did different was the nitrogen.
2014 XC Boss Blue/Gloss Black
Tri-Ovals
Lloydz ATS +4
Lloydz Air Filter
1/4 turn throttle
PBR300x2+Alpine SPS-510
Goody Lowers
Klock Works windscreen
2006 Suzuki GSXR 600
Kingsrule5 is offline
post #6 of 27 (permalink) Old 07-08-2015, 06:42 AM
I have a mix of about 78% nitrogen, and the rest is just a mix of oxygen and other ingredients.
post #7 of 27 (permalink) Old 07-08-2015, 07:12 AM
Hehehe. You've run rings around them with your danged chemistry.
G'day,
Vinish
Vinish is offline
post #8 of 27 (permalink) Old 07-08-2015, 07:16 AM
RGP
Isn't that called ....air ?
RGP is offline
post #9 of 27 (permalink) Old 07-08-2015, 08:23 AM
DillPickle311's Avatar
Ha! I put in air, vitamins, minerals, Viagra, but still need to check it once a week or so. Oh! I use a bicycle pump. Also, not all cheap air gauges are the same. Looking for a pro gauge now.
DillPickle311 is offline
post #10 of 27 (permalink) Old 07-08-2015, 08:36 AM
Foto Joe's Avatar
The American Sheeple will swallow just about anything the marketing departments can think up. I'm currently working on a concept vehicle with the Sierra Club, Green Peace and Al Gore that will counter the effects of gravity by using closed cell foam in the seat cushions that is infused with helium and an engine that runs on hydrogen. The reduction in weight afforded by using those two gases should allow the vehicle to not even need nitrogen in its tires let alone air.
I'm currently awaiting my government subsidy check in the amount of several billion dollars so that I can begin marketing this idea to the public and produce one concept car over the next decade.
Sorry, as an ex marketing person I just couldn't help myself. I shall now go lay down by my dish and let y'all debate 100% nitrogen over 78% nitrogen.
@"[email protected]_ _ _
Ambition is a poor excuse for not having enough sense to be lazy.
2017 Cross Country
Stage 1 & Tri-Ovals
Foto Joe is offline
