Oil Change - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 07-07-2015, 08:15 PM Thread Starter
Atbyrne's Avatar
Default Oil Change
need opinions on if I should change my oil before a 3500 mile ride to sturgis. It has about 1500 miles on it right now, and I will be riding up till I go. The change interval is 5000 miles correct.
2011 Cross Country
PCV with Vic filter
Witchdoctors Muscle Mufflers
Painted inner fairing
Magnum 21" Wheel and Fender
Custom mounted CVO Tour Pak
Vicbaggers Bars, speaker grills,
and bezels
Atbyrne is offline
post #2 of 12 (permalink) Old 07-07-2015, 08:27 PM
Motorbikerx's Avatar
That's correct 5000 miles, you've had your 500 mile service I presume.
Up to you, you could change it when you get to Sturgis just to be safe, I presume you're using Victory oil.
Miles are a bit low to go Full Synthetic.
Oil is cheap if you work out how much gas you'll use in 5000 miles running, its but a splash in the pan.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 12 (permalink) Old 07-07-2015, 08:39 PM Thread Starter
Atbyrne's Avatar
Well past the 500 mile mark. The bike Has 37000 miles on it. I will probably change it just to be safe.
I guess I should have specified that it had 1500 miles on the oil not the bike.
2011 Cross Country
PCV with Vic filter
and bezels
Atbyrne is offline
post #4 of 12 (permalink) Old 07-07-2015, 09:53 PM
I would just drive it more than you usually do. Then its worth it to change it before the trip
vcc14 is offline
post #5 of 12 (permalink) Old 07-08-2015, 04:28 AM
GatorJoe's Avatar
I always Change the Oil and Service The Bike Before a Road Trip of more than 2,000 Miles is just Cheap Insurance .. Check Tires, Brake Pads, Lube Cable Ends . Etc..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #6 of 12 (permalink) Old 07-08-2015, 06:06 AM Thread Starter
Atbyrne's Avatar
yeah i normaly do as well, just hate wasteing money. I am always on sucha tight budget these days, need to sell the other 2 bikes to finish paying for this one.
This is probably what I will do. I know the tires are good and pretty sure the brajes are. I will have to check the rear one.
2011 Cross Country
PCV with Vic filter
and bezels
Atbyrne is offline
post #7 of 12 (permalink) Old 07-08-2015, 11:17 AM
In Sturgis you'll ride in high heat and a lot of stop and go.
The smart thing to do would change before and when you get back home. Mileage will not be the factor the heat will be
post #8 of 12 (permalink) Old 07-08-2015, 01:10 PM Thread Starter
Atbyrne's Avatar
I think that is exactly what I plan to do. We will only be in sturgis sunday and monday for a little while. Long enough to talk to a buddy who owns Vicbaggers and to get a shirt form the Vic Tent and what ever Harley stuff my buddy wants to do. Than back home. It will bea long trip from Indiana through nebraska up through cheyenne, rock springs, Jackson, Yellowstone and on in to Sturgis. Than we head back via Iowa.
2011 Cross Country
PCV with Vic filter
and bezels
Atbyrne is offline
post #9 of 12 (permalink) Old 07-08-2015, 03:39 PM
theja1's Avatar
Yep, that is what I am doing. Although I will have about 3000 miles on this oil by the time I change it before Sturgis (at about 2100 now).
2003 Harley Davidson Sportster (RIP)
2006 Suzuki GZ250 (traded)
2012 Honda Shadow Phantom (traded)
2014 Victory Cross Country
theja1 is offline
post #10 of 12 (permalink) Old 07-08-2015, 08:32 PM
What a great road-trip!...I'm envious
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
