PCV W auto tune partII - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 14 (permalink) Old 07-11-2015, 07:22 AM Thread Starter
Default PCV W auto tune partII
Hi gang I know I have posted questions about PCV and auto tune and I am just about ready to pull the trigger on getting this. I have heard some pros and some cons about the auto tune. What's everyone's opinion. It is not practical for me to travel to get it dynoed, or I would .
Jim
Roanoke, Virginia (originally from Ithaca, NY)
USMC - Vietnam
2013 Victory Cross Country Tour
stage 1 Tri-Ovals
Lloydz wheel at +4
Lloydz Air Filter
Dynoed By Nick at 804 MotorSports
1" tank risers
O2 unplugged
1/4 turn ring
JPokerwinski is offline
post #2 of 14 (permalink) Old 07-11-2015, 07:42 AM
BP6666VR's Avatar
Autotune works fine .... there is NO dyno here
But compare the cost I would suggest, how much does the trip cost for you to Dyno and back ?
And how much does the AutoTune cost ??
You still need a good basemap that is NOT from PCV website
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 14 (permalink) Old 07-11-2015, 09:27 AM
I am saving money for a new tuner myself but now I am going back and forth between a PCV and AFR+. I'm a tinkerer and I know that I would have to have the bike dynoed everytime I change something if I have a PCV.
The autotune module is about $300US
post #4 of 14 (permalink) Old 07-11-2015, 09:33 AM
LILMAGS500's Avatar
Everyone that buys something other then a PCV always seems to end up with one in the end , do it right the second time broggy .
LILMAGS500 is offline
post #5 of 14 (permalink) Old 07-11-2015, 11:05 AM
dtmmil's Avatar
www.motomummy.com. i run the auto tune myself and really like it
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #6 of 14 (permalink) Old 07-11-2015, 11:22 AM
I don't understand why you can't take a ride and get a dyno tune. In the long run you would be better off
post #7 of 14 (permalink) Old 07-11-2015, 11:26 AM
Motorbikerx's Avatar
Why ask opinions if you've made up your mind?
Cant beat PCV and a pro-tune........Set and forget
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 14 (permalink) Old 07-11-2015, 06:59 PM
dtmmil's Avatar
nice thing about auto tune like broggy said, you can add or change stuff and just auto tune and accept trims. i added cams, accepted trims and away i go, still constantly tweaking, just because at times.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #9 of 14 (permalink) Old 07-12-2015, 12:19 AM
steveg56's Avatar
I like the auto tune. I have no surging, no popping, runs super strong and crisp. Now when I add my cams later, I can download a new basemap with cams and auto tune again to perfection. If I get some new slip ons or go to a 2-1 I'm just an auto tune(s) away.
Went on a trip with some buddies to South Lake Tahoe last week and let the auto tune set me up for the higher elevations...Dyno can't do that...just sayin
CdnSailor likes this.
2015 Magnum X1, AF, PTS, Vance and Hines Hi Outputs, PCV, AT-300
steveg56 is offline
post #10 of 14 (permalink) Old 07-12-2015, 05:56 AM
LILMAGS500's Avatar
Wouldn't it be better for you guys to set your maps to 0 and start from scratch ? doesn't the auto tune start building the maps immediately ? Just accept your trims more frequently , or broaden the range more then 20% to start . If I had the auto tune I would get out on the highway and make runs like they do on the dyno , and some blasts to WOT so every cell will be perfectly tuned . Its just so hard to tell what AFR's are providing you the most power at any given RPM or throttle opening without a dyno , sure , your bike may be running great , but again ,are you making the most power or leaving a lot on the table ....
