2 inch drop - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 07-12-2015, 08:33 PM Thread Starter
Edalfa's Avatar
Default 2 inch drop
Today I installed a witchdoctor 2 inch lowering link and shortened kickstand. First a big thanks to witchdoctor for the how-to videos. They really helped (especially the kickstand ). The lower bolts on the link and the shock were a bear. Watching Jon on the video, it looked easy. Thank God for breaker bars. The only real snag was the bolt that holds the pivot pin in place. The threads were boogered up when I removed it. Once I ran a die over the bolt, all was good and it went back together well. No test ride tonight. I was hot and the pool looked too inviting.
Edalfa is offline
post #2 of 18 (permalink) Old 07-12-2015, 08:54 PM
LILMAGS500's Avatar
Looks great Ed , I did the 1.5 drop a couple weeks ago ... A great mod !
LILMAGS500 is offline
post #3 of 18 (permalink) Old 07-12-2015, 08:56 PM
LILMAGS500's Avatar
I meant to also say , your belt will probably be way too tight now and will need adjustment , and so will your headlight ... WD doesn't mention this ....
post #4 of 18 (permalink) Old 07-12-2015, 09:02 PM Thread Starter
Edalfa's Avatar
Yeah, I was wondering about the belt and didn't even think about the headlight. I'll check it out tomorrow. Thanks for the reminder.
Edalfa is offline
post #5 of 18 (permalink) Old 07-12-2015, 09:05 PM
LILMAGS500's Avatar
Loosen your axle nut , back both adjuster nuts off exactly 1 full turn each , tap wheel forward , tighten axle nut ... Good to go .
post #6 of 18 (permalink) Old 07-13-2015, 09:51 AM
dtmmil's Avatar
he may need to go more with a 2" drop, but that will be better then not adjusting it.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #7 of 18 (permalink) Old 07-13-2015, 11:21 AM
ccrainman's Avatar
Quick question for you guys that did the lowering link. I have a buddy that is 5'7" with this link. Do you think he can be flat footed on the floor or a least close?
ccrainman is offline
post #8 of 18 (permalink) Old 07-13-2015, 11:41 AM
[QUOTE=ccrainman;1604097]Quick question for you guys that did the lowering link. I have a buddy that is 5'7" with this link. Do you think he can be flat footed on the floor or a least close?[/QUO
not knowing what lowering link he has he should come rear close to being flat footed.
Guys put 40 psi in your shock so you don't bottom out. Ride for a month all is good take 10 psi out and see what you think.
Remember you can't add air at 60 mph
post #9 of 18 (permalink) Old 07-13-2015, 11:42 AM
Bhunt19's Avatar
Speaking from experience!! I am a bit vertically deficient at 5' 5". I have the 1&1/2 in drop link installed, I can't quite get flat footed but It's close enough that I'm very comfy with my foot placement when stopped. (Backing up is admittedly a bit of a PIA) I leave 10 psi in the shock w/the trunk on. I'll drop it to zero if I pull the trunk. This seems to work well when riding by myself. When my prettier half jumps on, I bump the shock up to 62 psi. (She only rides with the trunk on)
It may take a little experimentation to figure out exactly where you're comfy at a stop, but it's one more great excuse to go for a ride!
On a side note, I weigh in at 180, and let's say my pretty half is much less!!
2014 XCT, Black, Stage 1 tune w/Tri Ovals, 1/4 turn, Lloyds A/F, ATS @+4
2006 VStar Custom
Bhunt19 is offline
post #10 of 18 (permalink) Old 07-13-2015, 11:43 AM
go slow out of driveways to prevent bottoming out exhaust
