13 Cross Roads Classic, loose gas tank? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-27-2015, 12:23 AM Thread Starter
VicTim's Avatar
Default 13 Cross Roads Classic, loose gas tank?
I just stopped to get gas on my 13 Cross Roads Classic with 19,000 miles and I noticed some play in my gas tank. Is it normal for the tank to be able to wiggle from side to side a little. I can also sort of lift it up a little. I'm not sure if this is standard or its actually loose. Does anybody know?
2013 Crossroads Classic
VicTim is offline
post #2 of 6 (permalink) Old 07-27-2015, 12:51 AM
Travis P's Avatar
Might have lost one of those rubber grommets...
Travis P is offline
post #3 of 6 (permalink) Old 07-27-2015, 05:55 AM
LILMAGS500's Avatar
Mine has some side to side play too , I think a very small amount is normal . If it seems out of the ordinary I would just get a new set of bushings , be about 15-20 bucks ....
LILMAGS500 is offline
post #4 of 6 (permalink) Old 07-27-2015, 10:43 AM
johnnyplano's Avatar
My tank is nice and tight. Not even a wiggle.
On yours, something is probably loose, misaligned, or missing.
I suggest you take the tank off and see what's going on.
Here's a Witchdoctors video showing how to install a Lloydz air filter, but there is a great section on tanking the tank off. (Starts at about the 2 minute mark)
Tip: It's a lot easier if you burn off most of the fuel.
2013 Cross Roads Classic
Tri-Oval Stage 1
Lloydz ATS
OEM Tachometer, Windshield Lowers, Driver & Passenger Backrests
Ultimate Midrider Seat
Kuryakyn Sabertooth Tail Lights
Ricz Lay Down License Plate Bracket
28,000 (s)miles and counting...
johnnyplano is offline
post #5 of 6 (permalink) Old 07-27-2015, 11:41 AM Thread Starter
VicTim's Avatar
I just called the dealer this morning and he said this was normal because of the rubber bushings. Thanks for your help guys.
VicTim is offline
post #6 of 6 (permalink) Old 07-28-2015, 05:34 AM
TNXR's Avatar
My XR that I have had for 3 years and 10k miles tank is tight as it can be, no wiggle.
2011 Cross Roads Sunset Red
TNXR is offline
